Volks AutosMonster Motorsport
    Dec 2012
    Norwich
    66
    My Brother's wiper knocking noise
    My brother has an 2005 A3 8P which has developed a problem with the wipers making a light knocking noise. Everytime the wiper blades return to the rest positon there seems to be a knocking noise and appears to be coming from the driver's side.
    Have changed his wipers with mine and the same problem is there. Again have looked with the bonnet up and the blades and arm seem to sit well enough away from the scuttle panel. Annoying that we can't activate the wipers when the bonnet is up to really get a good look.
    Any ideas would be much appreciated, thanks.
    Sportback owner
    Apr 2007
    France
    488
    Sounds like that there may be some wear in the motor/linkage mechanism. Try wiggling the wiper arms on his and on yours and see if you can feel any difference. Note also that on the A3, the car often nudges the wipers blades into a different position when they return to their resting place. This is to prevent the rubber blades from getting 'set' one way over time. Clever that! Otherwise, stand outside the car and observe the blades when they park. If they move a little when the knocking is heard, then probably the motor is still seeking the rest position (a microswitch may be out of adjustment). Good luck.
    French A3 Sportback 2006, 2.0L 140 TDI, DSG, RSN-E, Ambient lighting, Auto-lights/wipers, Reverse assist, Dolphin Grey, 17" wheels, Leather seats, Cruise control, Roof bars.
    Dec 2012
    51
    Hi i had the same problem with 2 A3s ive had turned out to be the mechanism on both occasions was also told this was a recall issue
  1. Knocking noise !
    By imported_ANNANBHOY in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th July 2005, 16:02
  2. knocking noise from front after lowering car
    By TDI in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th July 2005, 18:16
  3. knocking noise
    By chrisa4quat in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st September 2004, 23:26
  4. CLUTCH KNOCKING NOISE
    By imported_cudwuss in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th September 2004, 19:43
  5. Knocking Noise
    By L1ARR in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th September 2003, 17:19
