Badger5JMB Retrofits
    Nov 2012
    Blackburn
    61
    installl and now problems
    ive just recently fitted rnse and bluetooth to my car and i have a couple of issues.
    1. battery drain(bare in mind i have not coded the car). i removed the rnse yesterday night so it seems like the bluetooth module is it faulty or is it due to coding?
    2. pin entry. its a legit unit but guy i bought it off didnt get code from audi. he will supply me with details so will dealers sort this?
    3. airbag light. during the install i am definitely sure i did not disconnect the airbag so im slightly confused on why the lights on.
    going to get it coded from some dude in my area how much should it cost? dont want to get ripped off lol
    May 2012
    York
    241
    Air bag light sometimes comes on and off just due to the wires been knocked.
    Fossie
    Rhubarb Triangle
    3,969
    Airbag light will come on if you disconnect the battery. After a short drive it will go off ( the light, not the airbag !! )
    Some bluetooth modules are known to have this problem of battery drain but I don't know the reason or cure, sorry.
    Coding won't help the bluetooth problem but check the VCDS user map for someone in your area who could do it for you. Cost should only be a few beer tokens !
    Nov 2012
    Blackburn
    61
    yikes
    do you reckon i should just get a different module? or should i just wait until its coded. my battery died due to me working for couple of hours with the inside light on. so i cant be 100% its the module. also ive checked my connections and it seems like theres not wires for tel from my car? when i plug in the adaptor its loose and its obvious theres no connections
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by syk919 View Post
    yikes
    I suggest you try a process of elimination. First of all make sure your battery is fully charged. Then disconnect the bluetooth module and run the car as usual for a few days. If there does not seem to be any noticeable problem then plug module back in and run again for a few days.
    If the module has a problem then it will show. If no problem then it must have been working with the lights on that caused it, or some other unrelated cause, but I wouldn't have thought leaving the interior lights on for that length of time should flatten the battery.
    Jan 2013
    Hi there, new to forum so bear with me. I have also recently fitted a rns-e to my a6 Avant, I have a few problems with it though firstly, the unit to seems to turn itself off periodically then back on when it feels like it! I know that all the connections are good as each 1 been tested time and time again. secondly, I have all the info of the radio, cd and SD cards come up in the dis but nothing when using the navigation. Thirdly, I understand that I have to have the car coded with the rns-e. Does anyone live need the Coalville, Leicestershire area that could help me with these few issues. It would be so greatly appreciated.
  1. Local garage fitted new TIP and now problems :(
    By MILF in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st January 2013, 18:46
  2. Replies: 23
    Last Post: 21st July 2012, 20:58
  3. 2000 mk4 Golf Gti 1.8T with a few upgrades and now a problem
    By Gavin Simpson in forum The Project Room
    Last Post: 4th July 2012, 01:14
  4. knocking, now whining and power problems at 70 mph+
    By Kathryn1809 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st August 2010, 12:58
  5. I took the battery out of ny TT and now my radio w
    By jondana in forum TT/TT-S/TT-RS Forum
    Last Post: 18th February 2004, 19:19
Tags for this Thread
