Sky InsuranceAH Fabrications
Results 1 to 7 of 7
    Apr 2012
    London
    465
    Audi A3 S Line windscreen washer doesn't work?! Any help would be appreciated!
    Hi guys, as the title says I'm having problem with my A3 S Line's windscreen washer, only one of the pins seem to work fine from both sides, I believe there are 6 pins on both side, or maybe 8 pins, but only the very right one on the driver's side works, and that's not adjusted as well...
    Another one on the right hand side works fine, but needs some adjustments, tried to adjust but no luck! Aside from adjusting the pins, what this could be due to, as the rest of the pins don't work!
    I already took it to my local garage but they asked for 120 which I thought it's a ripoff for sure, so thought to ask you guys first and see if anybody else ever experience such problem or not...?!?
    26,777
    Pins or do you mean jet holes?
    3 holes per side, just get some thin wire & clean the holes out.
    Apr 2012
    London
    465
    Sorry for the explanation, but yeah I meant the 3 holes on each side!
    Only one of them seem to work, but that also needs some adjustments which I tried but no luck!
    Apr 2012
    London
    465
    Any idea how I could possibly access the pipes as it maybe due to the pipes!
    Also how can adjust these 3 holes on each side!
    26,777
    How can it be the pipes if one jet is putting water out, you need to get some thin welding or the like wire & clear the holes, I could be wrong, but every jet I have looked at with this issue, has been this.
    Use a pin to adjust the directions.
    Apr 2012
    London
    465
    Cool mate, thanks a lot for the reply! I'll give that a go tomorrow and post you an update!
    Apr 2012
    London
    465
    Thanks a lot mate, I cleaned them out and now absolutely fine, has the same problem with the rear jet washer and followed the same procedure and all fine...
  1. audi a4 1.8t both front windows not working, any ideas?
    By andyw82 in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th April 2012, 18:18
  2. Audi a4 b5 problems any help would be great
    By Crazymoesizzle in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd December 2010, 11:21
  3. Audi 80 TDI Electrical fault. Any help would be grand...
    By threeka in forum Classic Audi Forum
    Last Post: 6th September 2010, 06:14
  4. Windscreen Washers not firing?
    By jesters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th November 2004, 08:50
  5. 91 Audi 80 1.8 4 cylinder not fast enough any help
    By dan1972 in forum Classic Audi Forum
    Last Post: 26th April 2004, 16:07
Tags for this Thread
