Chris NottSky Insurance
Results 1 to 12 of 12
    Nov 2005
    UK
    584
    How to sort the rear suspension on my S3 ?
    My 2011 S3 s/back has the Eibach sportline front springs and I run RS3 19' alloys and tyres, but I have noticed a couple of times that if I am really pressing on around a bend, the rear seems to almost 'slew' sidewards....almost feels like it is trying to rear-wheel steer.
    The tyres are the correct pressures which makes me think this is an inherent characteristic for this model , in which case what have others done to make the rear feel more planted in fast corners ?
    The initial turn-in is great, it's just the transition at the rear from that point on.
    Thanks.
    26,722
    ARB upgrade.
    Nov 2005
    UK
    584
    Front and rear or just the rear ?
    26,722
    Rear is the easiest, so do this 1st, most arb's these days have adjustment holes to tighten things up more if need be.
    Nov 2005
    UK
    584
    Great advice as always....thanks for the quick response NHN
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,788
    NHN has given you his customary good advice.....the S3 from stock understeers like mad,and is a bit wobbly,so the ARBs are the first thing to correct,followed by the rest of the suspension if that mod doesn't go far enough for you.
    A decent set of coilovers adds a lot as well(but more cost too),and allows a lot more adjustment.
    JPK
    May 2012
    278
    Consider the rear trailing arm spherical bearing upgrade from 034 Motorsport too. I have a well sorted A3 with H&R suspension and a Whiteline rear sway bar and whilst its a massive improvement on stock, the rear is a little floaty at speed. Im going to purchase these shortly.
    Rear Trailing Arm Spherical Bearing Upgrade Kit, Volkswagen MkV/MkVI and Audi 8J/8P - 034Motorsport | Performance Parts for Audi, Porsche, and Volkswagen
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,788
    Quote Originally Posted by JPK View Post
    Consider the rear trailing arm spherical bearing upgrade from 034 Motorsport too. I have a well sorted A3 with H&R suspension and a Whiteline rear sway bar and whilst its a massive improvement on stock, the rear is a little floaty at speed. Im going to purchase these shortly.Rear Trailing Arm Spherical Bearing Upgrade Kit, Volkswagen MkV/MkVI and Audi 8J/8P - 034Motorsport | Performance Parts for Audi, Porsche, and Volkswagen
    I think the other things are worth doing first,but I've also had the Haldex controller uprated,and had the full Superpro fast road bush kit,and antilift kit fitted.....of all the upgrades,the ARBs and coilovers probably make the biggest single difference,but the others do help as well.
    RedDejavu's Avatar
    Feb 2011
    Bracknell
    1,332
    Do ARB front & back + anti lift kit you will not be disappointed!:D Just make sure you fit front soft and rear hard best combo and well worth the money.
    Be patient. English is tough.
    Now:
    61 Audi S3 BE S-Tronic Ibis White: Build Thread.
    / Black Edition pack (SatNav, Bluetooth) / Parking Sensors / Tinted windows / piano inlays and finish / Cruise Control / Interior light pack /
    /Mods: REVO Stage 2+: Revo Intake / Milltek Resonated TBE / LOBA HPFP/ GFB DV+ / Crystal Clear H11 FOGS / Black roof + spoiler vinyl wrap / H&R Anti-roll bars / Superpro ALK /
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,110
    ARB will dramatically improve the handling, along with coilovers as Alex mentioned, I'm going to fully polybush my car within the next month
    "Will these wheel fit my car PM's will not be replied to, do you research & use the SEARCH button"
    Detailing - Wheel Refurbishment - Shark Performance Software - VagbremTechnic Dealer - OEM Retrofitting - Remus - V-Maxx - Goodridge
    RedDejavu's Avatar
    Feb 2011
    Bracknell
    1,332
    Quote Originally Posted by S3Alex View Post
    Do you use this GEN4 uprated HPA competitor controller Alex? Have read some good reviews about it and thinking to give it a go at some point later this year. Would it be worth it just for the road use?
    Now:
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,788
    Quote Originally Posted by RedDejavu View Post
    As far as I know it's actually Gen.2,with a switched controller.
    I think it IS worth it,but it's not a huge difference,more of a subtle one,and certainly loads up the 4WD system quicker,and aids traction.
  1. How to remove the Rear wiper motor.
    By Legend7 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th February 2012, 23:00
  2. Replies: 3
    Last Post: 11th June 2011, 14:05
  3. any one know how to get the rear quarter window out?
    By stoneys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd September 2010, 09:29
  4. How low is the sport suspension?
    By awmw in forum Handling
    Last Post: 13th May 2008, 23:34
  5. how cramped are the rear seats?
    By youngdriver in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th April 2004, 19:12
