JMB RetrofitsChris Nott
Results 1 to 8 of 8
    Feb 2013
    9
    Red steering light and yellow esp light after battery was disconnected.
    Hi,
    I disconnected the battery today and once it was reconnected the ESP and a red steering light came on and won't go away.
    I've done some research and I've tried all the tricks like turning the wheel to the left and right and driving and such but it's still there.
    The steering is still powered.
    Had my parts dealer friend do a diagnostic and no faults were found. This wasn't a vagcom cable, but one of the £1000 diagnostic machines for all cars that he sells to garages.
    I think the battery may be on it's way out. It's at 55% capacity, unserviceable. Not sure if that's connected, but either way I'm getting that sorted tomorrow.
    Any ideas?
    Thanks a lot,
    Conor
    27,014
    Use vcds & scan, as vcds can pickup things allot others do not.
    Feb 2012
    Birmingham
    137
    I had these come up when i recently swapped my battery. Went out after driving about 100m from my drive.
    Feb 2013
    9
    Yeah, I've driven about, no change! I might have to get myself a VCDS set up!
    27,014
    I sell the genuine vcds, but maybe 1st get it scanned by a local owner 1st before going to that expense unless you'd like it for future diagnotics aswell, then its well worthwhile.
    Dec 2012
    51
    I had the exact same problem when i had a knackered battery in my 20ltr tdi A3, the battery died and after a jump started the lights were on but once a new battery was put in and the faults cleared away they went.
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    Those faults came up on my dash when I disconnected the battery and then reconnected again.
    They cleared within a mile of driving.
    Could anyone help me with some info on replacing the battery?
    I have bought Varta E44 and undone the clamps. Cannot pull the old battery out, something is holding it in place.
    Do I need to undo the airbox to gain access to the screw holding the battery in place?
    VCDS USER
    27,014
    13mm bolt on bottom left hand side needs undoing, mind the bracket held down by this bolt aswell.
  1. ESP light, Airbag light and yellow steering light
    By craigs3tdi in forum VCDS (formerly VAG-COM) forum
    Last Post: 20th July 2012, 10:27
  2. Engine Mgt Light and Trac Control lights on - HELP!!!!
    By razza1 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 24th March 2010, 08:55
  3. Side light and LED strip lights
    By stevereid in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd February 2010, 15:29
  4. squeeking brakes and ABS/ESP light
    By glen_jai in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th August 2009, 19:12
  5. air bag light and oil service light
    By zeeeebo in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th August 2009, 11:49
Tags for this Thread
