AH FabricationsVolks Autos
    Jul 2012
    12
    engine managment light
    Hi i was wondering if anyone could shed some light on an issue i have with my A3 2.0 TDI on a 56 plate, i occasionaly get the glo plug/engine management light warning light flashing on the dash board.The thing is if i stop the car and turn the engine off this kind of resets it's self and it might be ok for say a couple of weeks, then out of the blue it comes on again, i did get it checked by an independant machanic who got the fault code which stated it was possible a fault on the solidoid air inlet manifold, so after replacing this solidoid, approx 3 weeks ago the light has come on twice since, any help would be granted.
    Jun 2011
    127
    what was the fault codes? the solenoid? I guess he means egr valve
    Audi S3 2.0TFSI.. Milltek Turbo-Back Non-Res, ITG maxogen, THS FMIC, HPFP internals, Custom FR&RTuning dyno Software
    Previous
    Audi S3 1.8T with the following mods: Milltek Cat Back Non Res exhaust, with THS Decat, Induction kit , Forge 007P Valve and Custom FR-RTuning Stage 2 Software..
    Jul 2012
    12
    The fault code is 12600 the air intake manifold any suggestions?? Think it might be pricey??
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    683
    A new intake motor and flap is likely the worst it can be, and they can be had for under £100. Quite common for them to fail, we've done a few.
    Rick
    Unicorn Motor Developments. Bespoke Calibration and Remapping Services
    www.unicornmotordevelopments.com
  1. Engine management light on dash
    By imported_ashs3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th May 2005, 17:55
  2. Engine Management Light on all Week now off again
    By MingBluS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th May 2005, 21:54
  3. Help Engine Management Light On
    By taj in forum TT/TT-S/TT-RS Forum
    Last Post: 13th January 2005, 20:07
  4. Engine Management Light
    By Tendaimwari in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th November 2004, 21:11
  5. Engine Management Light
    By StephenBogan in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th September 2004, 13:06
