Badger5AH Fabrications
Results 1 to 7 of 7
    Sep 2007
    Swindon Wilts
    170
    Parrot ck3100 into my A3 with sat nav
    Hi
    I would like my bluetooth fitting into my audi that has the sat nav unit (rnse?).
    Is this a straightforward fit or a bugger to do that requires coding?
    thanks
    Sep 2007
    Swindon Wilts
    170
    27,121
    Is it a new ck3100 as it should come with its own looms/adapters.
    Thats purely an iso to quadlock adapter which you may already have, ideally need to plum in with some repair wires into the quadlock properly.
    Sep 2007
    Swindon Wilts
    170
    are the repair wires the ones from audi (I think I read about them somewhere!)
    thanks
    27,121
    Yes there are quite allot of different ones, but you'd need 000979009E's but you also would need possibly to solder the +/- wires to xisting rns power wires, unless as I advised before the ck3100 comes with adapters already.
    I could do all this for you, iirc you wnated cruise done aswell.
    Sep 2007
    Swindon Wilts
    170
    I've got cruise on the car I ended up buying - well remembered tho!
    Where are you based? I'm in Swindon wilts
    27,121
    Work all over the place, might have some work over your way at some point, PM me & we can discuss install costs.
  1. Replies: 0
    Last Post: 16th January 2007, 13:29
  2. A6 with sat nav
    By imported_christhick in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 11th April 2006, 19:34
  3. For those with Sat Nav
    By Platinum70 in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 18th November 2005, 22:34
  4. For those of you with sat nav but no tv
    By Eeef in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th October 2005, 20:14
  5. putting in sat nav (any1 with sat nav already)
    By pteyeo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th December 2004, 16:30
