JMB RetrofitsEM Tuning
Results 1 to 24 of 24
    Jonse's Avatar
    Oct 2012
    376
    S3 Hesitation between 3rd-6th gear and 3-4k rpm
    Hi All,
    I have done a search for this but can only find details for S3 8l.
    Basically when i accelerate hard i get a hesitation which last about a split second but is noticeable. This occurs when in 3rd-6th gear and around 3k-4k rpm.
    Below is a link of the exact issue im having:
    S3 choking/hesitating
    Do you guys think this can be fix by just replacing the spark plugs or is it something worse?
    I have also just checked my service history and looks like the sparks plugs have never been replaced. The car has cover 33k miles.
    Ryan
    Sep 2012
    Brum
    299
    Change plugs and coil packs mate.
    Jonse's Avatar
    Oct 2012
    376
    Do you guys have any links of recommend parts?
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,786
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    Jonse's Avatar
    Oct 2012
    376
    Ill buy these tonight and see if this fixes it
    27,089
    My friends S3 had same issue, I swapped out his plugs & it fixed the issue.
    Jonse's Avatar
    Oct 2012
    376
    Thanks, Im hoping it does fix it, because when i put my foot under its happening all the time
    Jonse's Avatar
    Oct 2012
    376
    Hi Guys, Plugged in Vagcom tonight and saw that my car is miss firing on all cylinders
    I have ordered a new set of spark plugs so should be here tomorrow. Really hope this fixes it.
    Acheron's Avatar
    Jan 2012
    South Africa
    263
    Sounds like a plug issue to me as well. Failing that it may be coilpacks
    Current: 2010 Audi S3 Sportback S-tronic
    Ex: 2007 Audi A3 Sportback - 2.0T DSG
    Ex: 2008 Opel Corsa OPC
    Ex: 2004 Opel Corsa Lite
    Ex: 1978 VW Beetle
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    Had this with my a3 it was missing on cylinder 2 started being intermittent but it became constant and same as yours under load. Changed plugs and all is well again :-)
    A3 Sportback 2.0 TFSI S-Line Quattro Stage 1 Tune it up - Lowestoft Custom Remap- 6187 RPM developing 260 bhp 279lbs ft Akoya Silver, Roof rails, Black heated Vienna Leather, Bose upgrade, Bluetooth
    Jonse's Avatar
    Oct 2012
    376
    Thanks for the replies. When i first did the reading it was the second cylinder then after trying on load it started across the rest.
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    I did also change the coil pack on 2 just to be on the safe side although I did have mine all done under recall last year but figured I might as well as that was the cylinder misfiring
    Jonse's Avatar
    Oct 2012
    376
    Is there a way to check if my car has had a recall for the coil pack?
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    Call audi they will be able to tell you from your vin worth checking as 4 arnt cheap!
    Jonse's Avatar
    Oct 2012
    376
    Thanks. Ill give them a call tomorrow.
    Jonse's Avatar
    Oct 2012
    376
    UPDATE
    I changed my spark plugs today hoping it would solve the issue unfortunately. It did resolve the problem. I will be ringing Audi tomorrow to see if my car has been re-called for the coil packs.
    I have a years Audi warranty, so hoping this issue should be fixed under that. I have fitted the revo air intake to my car. Do you think i should remove this before taking the car to Audi or you think they wont mind?
    Ryan
    Jonse's Avatar
    Oct 2012
    376
    Hi Guys just been looking on the net.
    And some sites suggest it could be bad fuel and when i think about it. It all started last time i filled up my tank.
    Could this be the reason?
    Ryan
    jimojameso's Avatar
    Sep 2012
    Surrey
    214
    It could be. Siphon the tank maybe if you have loads left and put in some fresh fuel. Worth a try.
    2010 TT RS - Sepang Blue - MRC 420BHP, 600NM
    2010 Stage 2+ S-Tronic S3 BE SB in Ibis White!! ....... SOLD
    Jan 2013
    159
    Are you using premium yes?
    Jonse's Avatar
    Oct 2012
    376
    Yeah ive been using shell V power, but i think when i last filled up it was the end of the tank.
    I will run the tank empty and see if this fixes it.
    27,089
    Be very careful, running it dry may dredge up the crap at the bottom of the tank & cause other issues like block fuel filter.
    Jonse's Avatar
    Oct 2012
    376
    Oh ok thanks. What would you recommend doing?
    Im waiting a phone call back from audi to see if my car was re-called for the coil pack.
    Jonse's Avatar
    Oct 2012
    376
    Hi Guys, Been looking alittle more into this issue and i think i got it wrong at first.
    After looking on videos on youtube i think my clutch is slipping as its doing this :
    Is a cluch under audi warranty?
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,359
    Possibly.....clutches are usually seen as wear items and may not be covered,but it IS worth giving it a fairly serious try.
  1. Acceleration hesitation between gear changes
    By lucksta in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th May 2012, 20:55
  2. Hesitation in 3rd gear.
    By SAiLO in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th September 2010, 08:49
  3. Replies: 1
    Last Post: 15th July 2010, 21:30
  4. S3 Rev'ing its self between 1.k-3k when not in gear, and very hesitant
    By VTI_EG_DAN in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th April 2009, 17:44
  5. pause in power between 3rd and 4th
    By philinman in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th December 2004, 13:39
