Chris NottAH Fabrications
    Nov 2012
    14
    Sunroof switch question
    Well basically I'm looking to add ambient lighting but having a sunroof and black roof liner makes things a little tricky when searching for a used light unit. At the moment mine looks like this
    And one that's cropped up looks like this
    My question is that I don't particularly like the two switch version and want to know if its possible to add my 'dial' switch off my old light unit? As you can see the two sunroof buttons on the new unit are surrounded by the 'dial' shape circle so would this just cut out for the dial slot into?
    i hope u understand all that lol..
    Acheron's Avatar
    Jan 2012
    South Africa
    263
    Shouldn't need any cutting, mate. The switch is already seperate from the surrounding trim so in theory if yours is the same size you should have no problem swapping the two around.
    Current: 2010 Audi S3 Sportback S-tronic
    Ex: 2007 Audi A3 Sportback - 2.0T DSG
    Ex: 2008 Opel Corsa OPC
    Ex: 2004 Opel Corsa Lite
    Ex: 1978 VW Beetle
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    I think the rocker switch is in such a stupid place.. have feel around with fingers to find it. Been better if it was on the row of buttons below the radio.
    Perhaps the rotary switch is easier to use.
    Nov 2012
    14
    Thanks that's all I needed to know.. I just think the rotary switch is more practical and looks better imo. Thanks
  1. Dashboard switch question???
    By Foxmeister in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd May 2010, 11:12
  2. Brake light switch question
    By Nick101 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th November 2009, 09:01
  3. Two switch Questions...hazard switch and light switch
    By sleeksx in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd August 2008, 23:59
  4. Sunroof switches
    By Strick in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th November 2004, 19:49
  5. A3 pic + door switch question
    By MsK in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th July 2004, 13:34
