Chris NottEM Tuning
Results 1 to 12 of 12
    Jan 2013
    14
    Wipers, horn and indicators not working
    My uncle bought an A3 2005 2.0tdi off a friend and the wipers (front and rear) indicators and horn do not work. He said the fuses all look ok
    any idea what the problem is?
    For info - before he bought it, the car had been sitting on the guys drive for a few months so it had got a bit damp inside - not sure if this would be related to the issue
    AndyA3170
    Fuses look ok, could be worth changing to rule it out
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    In The Sticks....
    2,611
    FULL BLOWN VCDS SCAN, be stupid not to.
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    Jan 2013
    14
    Just had another chat with him he said basically nothing that is switched on with the stalk works so he is thinking it could be a relay?
    mjr901's Avatar
    Nov 2011
    In The Sticks....
    2,611
    Quote Originally Posted by Deano82 View Post
    indicators and wipers are seperate relays are they not?
    wipers are variable ie it goes tick/click at various intervals depending on stalk control, indicators go 'tick tock'
    2 relays, and therefore 2 stalks out of sync.....nah
    Something else is going on there me thinks
    Maybe Earth Connection at fault.
    Boon's Avatar
    Sep 2012
    South East Kent
    335
    Sounds like the steering control module may have a fault & as said needs to be scanned with VCDS to find out. Very much doubt it'll be down to fuses or relays
    Jan 2013
    14
    Quote Originally Posted by Boon View Post
    He has taken off what he thinks is the problem, he said its looks like an ECU which was under the steering wheel, is this the steering control module?
    If so how much are these and where can he get one?
    Boon's Avatar
    Sep 2012
    South East Kent
    335
    Thats the steering control module...
    He will need the same part number as the current module, check eBay etc, just replace it BUT then...
    It will need to be coded... The basic settings for the steering need to be reset & any fault codes removed...
    this needs to be done with VCDS... Have a look at the VCDS User Map to find someone close to offer help
    Boon's Avatar
    Sep 2012
    South East Kent
    335
    26,716
    Whats the part number as I may have 1 in stock, also whereabouts is he located as it will need coding, aswell as the steering calibrated & various other calibrations.
    Jan 2013
    14
    He has bought a second hand module which has fixed the wipers and the horn but now when he puts the indicators on the main beam comes on and then after a few seconds the indicators each side will flash once in turn. seems strange do u think it may be faulty? or will it just need a reset
    26,716
    Whats the part number?
  1. Indicators not working properly
    By clcollins in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th April 2009, 08:51
  2. Indicators not working
    By Bula_82 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd March 2008, 21:30
  3. Interior lights and sunroof not working?
    By wayneharrow in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st February 2008, 17:15
  4. rear sub and speakers not working
    By nick-barnes07 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd October 2007, 08:31
  5. Replies: 0
    Last Post: 25th January 2007, 19:50
