AH FabricationsVolks Autos
    Dec 2012
    49
    Fault code 09571
    Hi anyone know what this code relates to 09571 , it was read after the coil light started flashing on my A3 20ltr sport. The coil light came on and off on 3 separate occasions but after a good hard run on the motorway stayed off ! confussed please help
    26,776
    09571 Turbo Boost Control Position Sensor Circuit Implausible Signal P2563 Intermittent.
    Dec 2012
    49
    Cheers but have you any idea what that is ?
    26,776
    TBH need a proper log of the car before guessing, so get it vcds scanned & show us the faulting modules logs with nothing removed.
    Dec 2012
    49
    Will do ive only had the car 4 days so itll be returned to the dealer for repair but ill ask for the data from the diagnostics and put it on to make sure they have done the right repairs cheers pal
    Jul 2011
    15
    How did you solved these man? I got same error today.
    cheers
  1. S6 Fault codes
    By bigmoose in forum General Technical / How To
    Last Post: 16th June 2005, 16:16
  2. Help: Fault code 16795
    By imported_rustys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd June 2005, 17:17
  3. information on fault codes
    By vwjin in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th October 2004, 00:45
  4. Fault Code
    By gman in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th July 2004, 16:44
  5. fault code
    By tp7n in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th December 2003, 14:05
