EM TuningJMB Retrofits
Results 1 to 8 of 8
Like Tree5Likes
  • 5 Post By SPARTAN91
Thread: BRAKE DISC SIZE GUIDE LIST (OEM FIT)
    SPARTAN91's Avatar
    RED FIVE STANDING BY
    Zookeeper Champion
    Nov 2012
    NORFOLK
    410
    Since I've been on ASN I,ve seen a few threads asking want size brake discs I have as standed so I,ve desided to put together the list I have from my Audi repair manual
    Your car will have 2 codes within it's build spec list that form part of the vehicals spec plate/sticker which can be found in the service book or under the mats in the boot.Heres a photo of mine.CODES 002.jpg
    The codes you need are on the second line of box 5 so mine are 1KD(rears) and 1ZE(fronts)
    So heres the list FRONTS 1ZA 1ZC 1ZM 1ZD 1LJ are 312mm
    1ZE 1ZP are 288mm
    1ZF are 280mm
    1ZK 1LK 345mm
    1LG are 370mm(RS3)
    REARS front wheel drive 1KD are 255mm
    1KE 1KF are 260mm
    1KQ are 255mm
    1KU are 286mm
    1KZ 1KJ are 286mm
    4 wheel drive 1KF are 260mm
    1KJ 1KU are 286mm
    1KW 2EA are 310mm
    (RS3 312mm)
    Hope this helps as you can use these codes when ordering new parts and will save you having to remove the discs first in order to find you size first.
    These code will also tell you the type of brake caliper/piston size/brake disc max and min thickness and pad thickness and wear limits.
    A3Kent's Avatar
    Different Gear
    May 2012
    1,065
    Nice work. Lee540 was looking for this info earlier. Perhaps that's what's made you put this up
    09 Audi A3 2.0 TDI 170 S-Line SB 8P3
    - Full Leather - LED DRL's - BOSE - Cruise Control - RNS-E Mk2 - AMI - Bluetooth - Folding Mirrors -
    VCDS owner - A3 Grille Install Guide
    A3Kent's Avatar
    Different Gear
    May 2012
    1,065
    By the way. You can put these PR codes into this to see what you car came with orginally
    PlanetVAG.com - VW & Audi PR Code Search
    shariain's Avatar
    May 2004
    Glasgow
    1,173
    Saved for the future. Thanks.
    S3 1.8t Ming blue with ivory leather & 18"tt alloys
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    Great info, thanks!
    VCDS USER
    Jun 2011
    Great Melton Norfolk
    1,344
    Nice one Mark!
    Jul 2013
    29
    Sorry to dig this up.
    I have 1KS ### 1ZA listed on mine
    So thats 312mm for the fronts, but the rears arent listed. MTEc replied
    "there are 3 sizes of rear - 260mm, 282mm and 286mm" for my car
    I have a 2011 A3 2.0tdi Quattro, Cheers
    Aug 2007
    375
    Quote Originally Posted by JoeDeeJay View Post
    I'm having the same issue...is it possible to fit 288 if you have 255mm without
    upgrading components?
  1. Brake disc sizes 2.0 tdi sport
    By mozza1202 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th February 2011, 16:31
  2. Brake disc sizes???
    By Higgsy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th October 2010, 20:56
  3. 3.2 Front Brake Disc Size
    By edition in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th February 2009, 18:32
  4. Brake Disc Sizes
    By ronny in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th February 2008, 10:10
  5. S4 front brake disc size?
    By Dan Gliballs in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th September 2006, 12:35
