Sky InsuranceVolks Autos
    Aug 2010
    23
    Lumpy idle when hot
    Hi folks I have been reading about the lumpy idle threads but most seem to be when cold my 05 20 tdi bkd engine is suffering from this even when hot the needle is sitting steady at 800 revs but the car is not running smooth
    it was serviced 4k ago new fuel oil and air filters ! Any suggestion welcome thanks
    Sportback owner
    Apr 2007
    France
    465
    Get a VCDS scan as soon as possible. Most likely there is a sensor playing up, and therefore not fueling the engine properly. Other than that, look for injector problems on this forum. Good luck.
    French A3 Sportback 2006, 2.0L 140 TDI, DSG, RSN-E, Ambient lighting, Auto-lights/wipers, Reverse assist, Dolphin Grey, 17" wheels, Leather seats, Cruise control, Roof bars.
    26,774
    Are you sure the fuel filter was done, as its not run of the mill on a service.
  1. B6 TDI 130 lumpy idle when warm problem
    By ian-r in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th April 2011, 23:45
  2. Rough/Lumpy Idle When Cold
    By AA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd December 2008, 21:42
  3. First impressions & lumpy idle when cold?
    By rowansbank in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th September 2006, 09:31
  4. Fixed Lumpy Idle.
    By Add7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th January 2005, 21:41
  5. Lumpy idle 2.0 TDI
    By steve184 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th January 2005, 12:28
