Badger5AH Fabrications
Results 1 to 7 of 7
    Jul 2012
    Shropshire
    32
    Rear Wiper stuck on!
    Hi Everyone,
    Just noticed an annoying fault with my car (2005 A3 8P1 2.0L TDi DSG 3 Door) the rear wiper has developed a mind of it's own. Once you put it on, it stays on. I do however have control of the rear washer jet. The only way to stop the wiper is to put the car into park. But as soon as you drive off and put the wiper on, it stays on.
    I've tried a few different configurations of wiper settings to try and regain control but it didn't help.
    What would people suggest I check first?
    Really appreciate your help.
    Jan 2013
    Wiltshrie
    85
    I have a similar problem with mine, you probably need a new wiper motor (revised version E) can get them on ebay for £80, your best bet is to take the plastic panel off the inside of the boot and have a look to see if the washer fluid hose is leaking aswell, and you could disconnect wiring until sorted
    Stol1975's Avatar
    Sep 2012
    227
    Had the exact same problem on my 09 sportback. Water had got into the motor. Got a new motor off eBay from Lincoln Audi for £80 and fitted it myself only yesterday. All sorted now but it's a bit of bad design it seems. It's quite satisfying fixing it yourself though, it's made me think I should really do my own oil and air filters too.
    audicruiser's Avatar
    Audi Heaven
    Somerset
    1,861
    Do a search, It's a common fault and been covered a million times!
    Scott
    Audi A3 Sportback 2.0T Quattro S-Line 2007 8P2
    Lava Grey, Exclusive Line Black/Silver Leather, Heated Seats, Bose, RNS-e, iPod, Auto Lights & Wipers, Interior Light Pack
    Mar 2012
    369
    What the others said - I had exact same problem. Make sure you get the right motor though - you do need the Audi one.
    Jul 2012
    Shropshire
    32
    Thanks everyone. You were all correct. Just had a look at the motor and its soaked. It's also run inside my boot release catch and corroded the terminals a little - guess that explains why opening the boot sometimes took a few tries.
    Anyway terminals cleaned and boot opens first time now. Will be getting revised wiper motor in the next few days.
    Thanks to everyone that replied!
    Stol1975's Avatar
    Sep 2012
    227
    REAR WIPER DOING STRANGE THINGS?
    Follow the above link and get the wiper removal tool off eBay. It's worth it. Hope the link works as I copied it from another thread.
  1. help needed FAST, stuck on remoal of rear wiper.
    By supanova in forum General Automotive Chat
    Last Post: 8th March 2011, 14:31
  2. rear wiper
    By imported_velcrobix in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd October 2004, 23:49
  3. rear wiper stuck
    By Haris in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th July 2004, 15:44
  4. Stuttering rear wiper
    By ben in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd December 2003, 22:15
  5. replacement rear wiper arms
    By Khufu in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th September 2003, 14:54
