EM TuningVolks Autos
Results 1 to 7 of 7
    Mar 2011
    16
    2007 A3 2.0 TDI 170, Clutch Switch Location?? Help
    Hello All,
    Ive just fitted Retrofitted Cruise Control Stalk & ECU to my A3.
    Coded it all in correctly, In Engine & Steering
    However it dont work :/
    In VCDS i go to Measuring Block 006 in engine. It shows my brake switch is working, however doesnt register anything on the clutch pedal.
    I cant seen to see the clutch swith and I am struggling trying to find any info regarding this.
    Can anyone help?
    Thanks Dave
    Mar 2011
    16
    Nobody any ideas?
    Thanks Dave
    27,097
    Clutch switch would be above the clutch pedal.
    Mar 2011
    16
    Ive looked above the pedal and cant see it at all. had all the under cover off to look for it.
    Mar 2011
    16
    Still have this issue? Does anyone know exactly where the clutch switch is?
    regards dave
    27,097
    Check the brake switch again, the clutch has a hall sender on the back end of the master cylinder, doubt its this, I would join the wires temp on brake switch as sometimes it can register as working, but not be so.
    Mar 2011
    16
    i will try this tomorrow. Will let you know how it goes.
  1. 2007 2.0 TDI 170 DSG, very jerky 1st gear!
    By paultaylor in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd October 2011, 15:34
  2. Help ! 2007 b7 a4 tdi 170....engine will not turn over
    By vw754 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 11th August 2011, 19:54
  3. audi a4 tdi 170 2006 - 2007
    By michael mcd in forum The Welcome Section
    Last Post: 26th July 2011, 08:31
  4. 2007 A6 2.0 TDI 170
    By P Crr in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 21st April 2011, 18:37
  5. 2.0 TDI 170 max torque through the clutch?
    By Lukeyb in forum Tuning
    Last Post: 28th December 2008, 01:23
