EM TuningSky Insurance
    Jan 2013
    Leicester
    Brake pedal travel
    Right I got my a3 s line last Saturday and over the week iv noticed the brake pedal goes down further than my previous car and my van. Is this common or are my pads and discs on there way out the car has only covered 30000 miles. If iv gotta do the pads and discs I'd be inserted in fitting s3 calipers if its possible so my next question is are they a straight swap for a3 calipers also iv found some s3 parings fairly cheap so will they fit and are they any different to my s line springs. My cars a 58 plate facelift.
    26,774
    Check fluid levels, maybe do a flush with new fluid which will also get rid of any air in system with luck.
    You need the correct carriers for the 345mm S3 calipers to fit your hub's.
  1. Long travel on brake pedal after bleeding.. Help!
    By Rice in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th November 2012, 13:19
  2. Long travel in brake pedal .. Help
    By CheekyAudi in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd July 2011, 15:54
  3. Long brake pedal travel
    By <tuffty/> in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st July 2010, 19:32
  4. Looooong brake pedal travel
    By btmotorsport in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th April 2010, 16:16
  5. Brake pedal travel after brake upgrade!
    By Stevie C in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th August 2008, 17:48
