JMB RetrofitsSky Insurance
    Feb 2013
    Trowbridge
    Replacement clutch - should I upgrade and remap at the same time?
    Hi all,
    Great forum! First time poster and I did check the other posts on clutches and flywheels but I didn't really get a clear picture, so here goes.
    I've got a 2005 A3 2.0 TDI 138BHP (8P1) which is needing a new clutch at 92,000 miles. As I gather you're supposed to change the DMF at the same time my local garage has quoted £1050 for replacing the clutch and DMF with straight replacements. My question is: as I'm getting it replaced anyway and was considering a remap up to 170-180BHP, would it be in my interest to go with a upgraded clutch? I presume that as it's a diesel I wouldn't want to change to a single mass flywheel?
    Lastly, I live near Bath. Where would you guys recommend I get the work done? I don't mind travelling a *little*.
    Many thanks!
    dex140's Avatar
    Dec 2009
    190
    If you get it done now you wont have to pay labour twice if you were to get an uprated on fitted later down the line!
    Digzz's Avatar
    "Started From The Bottom"
    Jan 2009
    London
    1,383
    I'll get it done if I was u.
    Feb 2013
    Trowbridge
    Thanks, from reading online it seems that just a Sachs replacement would be better?
    Has anyone used Angel Tuning for their remap? I was thinking either them or just using a bluefin.
    tdi-man's Avatar
    Jul 2009
    1,612
    YES i have sachs dmf with a helix clutch to match .
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm (NEEDS A NEW MAP)
    Jan 2013
    Wiltshrie
    85
    Also remember the turbos on these are crap (technical term) so a remap may finish the turbo off,
    Remap on this car makes a really good difference just bare the turbo in mind
  1. DPF removal and remap in the South
    By SuperPuper2000 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th January 2013, 15:32
  2. Replies: 5
    Last Post: 17th January 2010, 22:49
  3. ?? are Manual and Dsg engines the same ??
    By shah786 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th April 2009, 15:18
  4. S3 210/225, do they really remap to the same power?
    By Painey in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th April 2009, 14:32
  5. avant and saloon coilovers the same???
    By M22_PRE in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th February 2008, 21:36
