AH FabricationsJMB Retrofits
    dex140's Avatar
    Dec 2009
    190
    Error Code- P261a coolant circulation pump
    Hello,
    Been looking at an a3 for th missus and the one we have been to see (from friend of family x lease handback) has an error code P261a coolant circulation pump open circuit. The car is a 09 2.0tdi 140bhp. From what i have read this is the pump that circulates water around the engine when it has been turned off..Is this correct? Would this cause any issues? If we do decide to take the plunge i will disconect pupmp and clean the connectors etc to see if this does the trick but if not i will replace. Has anyone else has this error?
    cheers
    Dex
    dex140's Avatar
    Dec 2009
    190
    Decided against car now as Audi wouldnt budge on price!
    27,072
    If its from audi, then it would be fixed anyway & covered by warranty.
  1. Error code 00519
    By Jules in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd August 2005, 12:18
  2. error code 00575, and sqealing noise
    By lowrider786 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th July 2005, 23:38
  3. S4 Error Codes?
    By SonicDeathmonkey in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th April 2005, 19:47
  4. Error codes!
    By S4ZippyZoo in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th November 2004, 12:43
  5. Flashing error code- "1n 1"
    By randallons in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th October 2004, 12:27
