EM TuningVolks Autos
Results 1 to 9 of 9
    Mar 2010
    Cleveland, North East
    214
    Downpipe removal on 2.0 TDI Quattro
    I'm having a bit of an issue with my 140 quattro.
    I'm in the process of swapping out the turbo (suprise, suprise) but can't seem to get the downpipe out, does anyone have any hints or am I going to need to drop the subframe?
    27,114
    With the fwd it just pops of the turbo & goes through the gap between subframe & exhaust channel as such, as I've done it numerous times now & got to do again possibly this weekend arrgghhh, but guessing with the quattro shaft, thats blocking the exit as such, so looks like sub has to drop, I will check elsawin when got a minute to be sure.
    27,114
    Whats the engine & gearbox code?
    Mar 2010
    214
    Yeah, I've dropped the propshaft and can see how it would be real easy on a FWD.
    If you wouldn't mind checking that would be great.
    Mar 2010
    214
    Engines a BKD, unsure on the box
    27,114
    Inside page of service book shows engine & box code.
    Mar 2010
    214
    Engine is BKD gearbox is FUQ
    Mar 2010
    214
    The answer is, it comes out with no need to remove anything else.
    BFI prevailed
    27,114
    Sorry mate, tiring day & forgot to reply, buttt, I checked in elsa for your codes & it only showed one route for either 4wd or fwd, as I advised before, drop down through the sub/chassis gap.
  1. 2.0 Tdi Quattro De-cat downpipe? Anybody know where to get one
    By asasprey in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd March 2011, 19:27
  2. Audi A6 2.5 TDI Quattro - Engine Removal Help (Broken Cam Followers)
    By Craig! in forum General Technical / How To
    Last Post: 17th December 2010, 15:39
  3. Audi A6 2.5 TDI Quattro - Engine Removal Help (Broken Cam Followers)
    By Craig! in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 9th September 2010, 15:05
  4. Turbo noise - 1997 1.9 Tdi Quattro
    By Holywood in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th August 2003, 15:36
  5. 1997 A4 1.9 Tdi Quattro - turbo noise
    By Holywood in forum The Welcome Section
    Last Post: 26th August 2003, 15:10
