JMB RetrofitsBadger5
Results 1 to 19 of 19
Thread: Lee 2.0TDi 170
    Aug 2012
    115
    Lee 2.0TDi 170
    Hi all,
    Just posting up to show my 2009 Audi A3 2.0TDi 170 S-Line..
    Is this a facelift? 8P3 as referred to on here?
    I like the car, but would like to do a few little mods.. de-badge, de-chrome front grille and add cruise control. Any tips or advice?
    I also fancy having the wheels a little darker, but not black and perhaps dropping it a little, 20mm or so on something decent like Eibach springs.
    Thanks for looking
    Lee
    Mr. B's Avatar
    English...not so good
    Jan 2012
    Bristol
    940
    Nice! How about LED DRL Headlights?
    Aug 2012
    115
    Quote Originally Posted by Snipe View Post
    What about them? I don't have them or xenons.. do you mean the christmas tree lights? or just replacing the DRL's to an LED bulb as opposed to the standard halogen type in there now?
    I was going to put in my original post, but might as well put it here now.
    My bootlid will ONLY open with the key, it wont open any other way, I almost locked my keys in there last week when changing my shoes to site boots at work. Is this normal?
    27,072
    May need coding to allow opening via the lid latch.
    Give me a shout if you want cruise fitted, also can fit the bixenon with led drl headlights
    A3Kent's Avatar
    Different Gear
    May 2012
    1,065
    I've got the black edition front grille thatll fit your facelift here - Classifieds: Audi A3 8P 2008-12 Black Edition/Optics Grille
    also got the matching s-line black edition fog grilles here too - Classifieds: A3 and S3 Fog Grilles For Sale
    drop me a pm if your interested
    09 Audi A3 2.0 TDI 170 S-Line SB 8P3
    - Full Leather - LED DRL's - BOSE - Cruise Control - RNS-E Mk2 - AMI - Bluetooth - Folding Mirrors -
    VCDS owner - A3 Grille Install Guide
    Jul 2012
    195
    BLACK WHEELS ...Mean & Moody....&
    A3's BLACK Grille.
    Aug 2012
    115
    Quote Originally Posted by A3Kent View Post
    Thanks for your post, I'd already seem then for sale but was wondering if I was able to fit the honeycomb S3 type grille and fog light covers? Do I have the right bumper?
    Aug 2012
    115
    Also, Looking at Eibach Pro Kit to give me 20mm drop? Are S-lines lower than a standard A3 with same engine? Does it make a difference whether or not have electric going to the suspension and how do I tell if I have this?
    I'm happy to fit all parts myself, will just have to find someone to do my geometry afterwards, how low before you would require camber correction?
    A3Kent's Avatar
    Different Gear
    May 2012
    1,065
    Quote Originally Posted by Lee540 View Post
    The honeycomb RS3 grille will fit yes, although it's quite expensive and difficult to get one in the UK. Try eBay.de (Germany) as Rob has mentioned in another thread posted yesterday I think. - See this thread - Honeycomb grille
    The S3 fog grilles won't fit your car. You will only be able to fit S-Line fog grilles, which I have a couple of variations of (Black Edition and Glossy Black with Chrome Surround).
    Obviously you could put an S3 bumper on but that depends on your budget.
    Aug 2012
    115
    Thanks for your reply, I wouldn't bother with the honeycomb unless I could fit to the fogs as well, might look a little odd otherwise.
    How does the optics grille differ to the standard grille? Other than the black outline? What kind of finish is this? Is it durable?
    A3Kent's Avatar
    Different Gear
    May 2012
    1,065
    Well, have a look at Rob's on here. He has it on his white S-Line. He might be along shortly and could post a pic for you if you can't find it.
    The only difference is the Black Edition one has a Glossy Black Surround as apposed to the standard Chrome surround. Both are identical apart from this. The one I have is genuine too so it's as durable as the standard grille.
    Here's my A3 S-Line with the grille on. If you look at my signature you will find my fitting instructions too.
    A3Kent's Avatar
    Different Gear
    May 2012
    1,065
    Here's mine before I changed the grille - (I actually think the internal plastic where the number plate is etc is black as apposed to dark grey on the original)
    Aug 2012
    115
    Ok great, thanks for the reply. I think I want these, one of my fog light surrounds has a whole in it, think a stone went straight through it so instead of changing that, I could go all black.
    What are you headlights? They look different to mine and we have the same car
    A3Kent's Avatar
    Different Gear
    May 2012
    1,065
    OK. Cool, i'll drop you a PM.
    The headlights are Xenon LED DRL's. Can be fitted but quite expensive, probably into your thoasands as it's not just a case of putting new headlights in. NHN (Nigel) is your man on here if you want these done.
    Aug 2012
    115
    I don't want to be spending thousands on lights, but happy to spend a few hundred on little bits and pieces.
    Slightly lower, black grilles, de-badge, lamin-x fogs is all I want externally
    Ash B's Avatar
    Jul 2008
    Cardiff
    5,806
    Like the car Lee and like the sounds of the plans. Look forward to seeing them
    Dark Vader Half sibling - MyThread
    Aug 2012
    115
    Quote Originally Posted by Ash B View Post
    Seeing your car, the grey one made me start looking at all this black stuff!! Its your fault
    Did you do camber adjustment after lowering
    Ash B's Avatar
    Jul 2008
    Cardiff
    5,806
    sorry dude. Yeah mate got the camber done on the rear of mine.
    Aug 2012
    115
    Back when I was younger.. 18, I dropped Astra Mk4 60mm and ripped through set of 17's down to the wire on the inside and didn't even realise, serious negative camber!
    Next on list for this car is front tyres and brakes, then I can play!
  1. 2.0TDI-170 fuel comsumption
    By h5djr in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th July 2007, 22:39
  2. 2.0TDI 170
    By howatsi in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 20th October 2006, 16:54
  3. new 2.0tdi 170
    By jonmusicman in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 15th July 2006, 10:38
  4. New A3 2.0TDI 170 - prices
    Last Post: 28th June 2006, 10:45
  5. 1.4TSi and 2.0TDi 170
    By mfspen in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th March 2006, 14:47
