Volks AutosBadger5
    Jan 2013
    South West
    42
    V6 Suspension Mods?
    sorry if this has been covered already but cant find where!
    After tralling threw many of the threads about how to get more power out of my V6 i've come to the conclusion i probably wont bother my ass. Instead i think i'm going to concentrate and handling first then aesthetics a bit later.
    Whats the thoughts on the following two links?
    Bilstein B12 Pro-Kit Suspension Kit With Bilstein B8 Dampers Lowers Front 30mm and Rear 30mm - Demon Tweeks
    H&R Anti-Roll Bar Kit 24mm Adjustable Front Bar 26mm Adjustable Rear - Demon Tweeks
    Surley these would help make the car stick to the road? or would coil overs be more suitable?
    Dec 2012
    Hordnean, Hampshire
    157
    You would imagine most spring/damper mods would help, simply by lowering the center of gravity and reducing body roll. A set of coilovers would give you more control over that and the ability to adjust it to your specific preferences. Roll bars, strut braces, under body braces, uprated suspension bushes/top mounts, uprated engine/gearbox/diff mounts etc. can all be fettled with.
    All depends of course for what purpose you intend to use the car and then tailoring the mods to that use. Wouldn't need to go so far for road use, whereas track use would benefit from more work
    27,029
    I actually have an iirc HR 24 or 26mm arb to sell, never used.
  1. What suspension mods
    By Aurom in forum Handling
    Last Post: 12th July 2004, 15:14
  2. Suspension mods for 1.8T
    By Aurom in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th April 2004, 21:44
  3. Suspension mods
    By Woodster in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th April 2004, 20:33
  4. TTC 225 Suspension mods
    By CarloTT in forum TT/TT-S/TT-RS Forum
    Last Post: 22nd January 2003, 23:30
  5. Passat Estate 1.8T suspension mods
    By CarloTT in forum Volkswagen and other VAG
    Last Post: 20th January 2003, 18:36
