JMB RetrofitsChris Nott
Results 1 to 8 of 8
    Tay
    May 2012
    Warrington
    366
    Help with a Couple of VCDS Faults
    Hi there, first of all I'm new to VCDS. I have carried out a scan to a check engine light which came on at random a day ago and wondered if anyone can offer any help with the two faults which I have, my car is a 2007 8P S3...
    Fault 1
    Address 01: Engine Labels: 06F-907-115-AXX.lbl
    Part No SW: 8P0 907 115 H HW: 8P0 907 115 B
    Component: 2.0l R4/4V TFSI 0050
    Revision: 5BH16--- Serial number: AUX7Z0G4FNU04W
    Coding: 01030003180F0060
    Shop #: WSC 06314 000 00000
    VCID: 377B6EE2463871A0D06
    1 Fault Found:
    001089 - EVAP Emission Control Sys
    P0441 - 002 - Incorrect Flow - Intermittent - MIL ON
    Freeze Frame:
    Fault Status: 10100010
    Fault Priority: 0
    Fault Frequency: 20
    Mileage: 101221 km
    Time Indication: 0
    Date: 2012.12.04
    Time: 15:30:25
    Freeze Frame:
    RPM: 850 /min
    Load: 15.7 %
    Speed: 0.0 km/h
    Temperature: 78.0°C
    Temperature: 27.0°C
    Absolute Pres.: 1010.0 mbar
    Voltage: 13.843 V
    Fault 2
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
    Component: Tuer-SG H02 0040
    Coding: 0000560
    VCID: 4481092E07EE2A38454
    1 Fault Found:
    00933 - Electric Window Motor; Passenger Side (V148)
    005 - No or Incorrect Basic Setting / Adaptation
    This fault has confused me slightly, as the window is operating completely fine and the coding is the same as the drivers side door module.
    Another thing I need to do is reduce the voltage supplied to the DRL Bulbs, as I've fitted some 9W Cree LEDs supplied by Trups and can't figure out how to make this change.
    I have done some coding for coming home lights, remote window functions and others which have all worked fine which is good news
    27,029
    Check here for the engine code:
    P0441 EVAP Emission Control Sys: Incorrect Flow
    The door error is just the one touch system, just run it all way up & hold button at top for 10 seconds, then run all way down & hold button at bottom for 10 seconds, then go into module & clear/check for errors.
    Fossie
    Rhubarb Triangle
    3,969
    Not sure you can reduce the voltage to DRL bulbs can you (Nige ??)
    Tay
    May 2012
    Warrington
    366
    Thanks Nigel, ill have a check of what the guy in the thread did to solve the problem.
    And the voltage can apparently be changed (or a similar method) to suit the LED bulbs, that's what I was advised by Trups a while back.
    27,029
    No, it has a set specification for a coding option, so expects to see a certain resistance etc, so if you have an option for bixenon, it looks for what it should get for when they're connected, same as halogen & same as say number plate led's on newer 8P's.
    Tay
    May 2012
    Warrington
    366
    All sorted now thanks for the help bulb error was removed by coding the headlights as the option with Led DRLs as opposed to seperate DRLs.
    27,029
    Thats exactly what my post advised then lol, the coding changes what it should see/expect, anyway you're extremely lucky as not all led's will be registered the same, lucks on your side.
    Tay
    May 2012
    Warrington
    366
    I know I must be very lucky, on the other side I'm getting hooked at discovering what can be done with VCDS, tempting me more and more with some of the retrofits, which ill probably be in touch with you about Nigel
  1. Help with a couple of problems 1.8t
    By vroomtshh in forum General Automotive Chat
    Last Post: 17th September 2012, 09:53
  2. Help with Air conditioning fault codes from VCDS Please.
    By Matt 77 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th August 2011, 20:30
  3. Need help with Fault codes please
    By xlr8 in forum VCDS (formerly VAG-COM) forum
    Last Post: 10th August 2007, 22:57
  4. Help with recorded fault code
    By Damian s in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th March 2007, 18:33
  5. Help with Fault Code
    By madkebab in forum VCDS (formerly VAG-COM) forum
    Last Post: 23rd February 2006, 13:15
