Hi there, first of all I'm new to VCDS. I have carried out a scan to a check engine light which came on at random a day ago and wondered if anyone can offer any help with the two faults which I have, my car is a 2007 8P S3...
Fault 1
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 8P0 907 115 H HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0050
Revision: 5BH16--- Serial number: AUX7Z0G4FNU04W
Coding: 01030003180F0060
Shop #: WSC 06314 000 00000
VCID: 377B6EE2463871A0D06
1 Fault Found:
001089 - EVAP Emission Control Sys
P0441 - 002 - Incorrect Flow - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100010
Fault Priority: 0
Fault Frequency: 20
Mileage: 101221 km
Time Indication: 0
Date: 2012.12.04
Time: 15:30:25
Freeze Frame:
RPM: 850 /min
Load: 15.7 %
Speed: 0.0 km/h
Temperature: 78.0°C
Temperature: 27.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.843 V
Fault 2
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Component: Tuer-SG H02 0040
Coding: 0000560
VCID: 4481092E07EE2A38454
1 Fault Found:
00933 - Electric Window Motor; Passenger Side (V148)
005 - No or Incorrect Basic Setting / Adaptation
This fault has confused me slightly, as the window is operating completely fine and the coding is the same as the drivers side door module.
Another thing I need to do is reduce the voltage supplied to the DRL Bulbs, as I've fitted some 9W Cree LEDs supplied by Trups and can't figure out how to make this change.
I have done some coding for coming home lights, remote window functions and others which have all worked fine which is good news
Fault 1
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 20
Mileage: 101221 km
Time Indication: 0
Date: 2012.12.04
Time: 15:30:25
Freeze Frame:
RPM: 850 /min
Load: 15.7 %
Speed: 0.0 km/h
Temperature: 78.0°C
Temperature: 27.0°C
Voltage: 13.843 V
Fault 2
Coding: 0000560
1 Fault Found:
