Results 1 to 10 of 10
    Nov 2011
    Broken the accelerator plug :(
    I've pulled a few wires out the accelerator plug trying to get the damn thing off, is there anyway of fixing it, or is it new plug jobbie?
    Also after I took the carpet out, I noticed the passenger side footwell was a little damp, is there a grommet that's been leaking water? It seems to be coming from up behind the dash
    27,114
    Have you pulled them out as a whole or broken the wires aswell?
    Nov 2011
    I believe I've broken the wires, as there's bare wire showing, do they go into pins in the plug?
    27,114
    Oh dear, it will need repair wires soldered onto ends to fit into the plug, which if you broke, this will need replacing.
    Nov 2011
    Would it be easier to get a plug from a scrap yard and solder it on?
    27,114
    Are you taking the piss?
    Nov 2011
    Ok ignore that
    have you got the repair wire part number, and by any chance know which wire goes where?
    Connections 4,5 & 6 have come out, and the coloured wires are brown and blue, grey and blue, white and blue.
    27,114
    Well you could reuse the plug, but you need the correct pin removal tools & if you wanted to use a new plug you still need to remove the good wires/pins to refit in new, so cut all.
    The wires are 0.35 x 5 & 0.5 x 1, so you can use 0.5 for all & the wires are 000979025E about £5 each, I suggest buying 3, cut in half, solder/heatshrink all 6 wires again so you have some slack in looms, brown/blue is pin 6, grey/blue is 5 & white/blue is 4.
    Nov 2011
    Ok, thanks for your help mate
    27,114
    There's a thanks button bottom left of posts
  1. can you compression test a bkd through the glow plug holes
    By nokia_aid in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th November 2011, 16:50
  2. Where are the glow plugs? (A3 2.0TDi)
    By LSH in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th November 2009, 10:44
  3. Whats the yellow plug on back of head unit
    By aaa3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th August 2009, 15:10
  4. Amending the timing of the spark plugs?
    By Wicked666 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th August 2008, 13:22
  5. Where's the acceleration?!
    By imported_slinx in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th August 2004, 21:20
