Badger5Sky Insurance
Results 1 to 7 of 7
    Jan 2012
    powys
    59
    how low should i go
    these are some photos of my 3.2 v6 sport my wheels are 17 inch , i dont mind the wheels , how ever i would like some genuine roters , but all down to cost , and after market ones are alot heavier .
    the question is how low would look ok with my standard wheels to fill the arch nicely . it looks very high , are my shocks the same as a sline but with different springs , my dad has a standard 1.9 deisel and it is higher than this .
    i think my car is 15mm lower than standard. and the sline is 25mm lower and the s3 is 35mm lower than standard.
    so if this is the case if i brought 35mm lowering springs it would lower my car 20mm is this correct ?
    27,105
    Grab some eibach pro springs, Damian@dpm would be good to talk to & buy from, top bloke for these things, that would give it a nice height, depends what you want it to look like, ideally 18's would be best for that kind of setup.
    rOb_A's Avatar
    May 2010
    cheshire
    1,485
    my car is a s line but now on eibach sportlines, giving a 50mm drop at the front and 40mm at the rear, over standard springs. sits about right for me on the 18" rotors.
    yep go to Damian for a price
    Turbo jay's Avatar
    Leather repair specialist
    Jul 2012
    North west
    550
    Yes if your car is 15mm lower than standard, then 35mm springs would take it 20mm lower so you will be at s3 height.
    Also H&R is another option, I went for them over the eibach.
    27,105
    Afaik Damian does all types
    Feb 2012
    Birmingham
    137
    I have the eibach springs and 17" std alloys on my tdi. They are great but do tend to catch speed bumps . Maybe 18" would irradicate this.
    Jan 2012
    powys
    59
    thanks for that i will speak to damian ,
    are my shocks the same as sline shocks. but with different springs ?
  1. how low should i go?
    By neil205 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th September 2008, 23:49
  2. How low should I go?
    By elucidate in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th March 2006, 19:33
  3. How much should i expect to pay?
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th April 2004, 11:32
  4. URGENT! - How much should i pay?
    By kmpowell in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th October 2003, 17:01
  5. How low would you go.....?
    By [Dave B] in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th June 2003, 15:21
