Chris NottSky Insurance
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By NHN
Thread: A3 3.2 camchain,replace vvt at the same time ?
    Jan 2013
    Question A3 3.2 camchain,replace vvt at the same time ?
    Hello , nice to be a member of your busy forum,looks good
    Is it worth replacing the variable valve timing unit at the same time as the stretched camchain as i heard both are engine out jobs ,is the vvt unit likely to fail over time, its done 88000 and i intend to keep it for a good while yet.
    26,721
    Welcome to the forum.
    TBH I didnt even know 3.2 was vvt, but I've not heard of this being neccessary tbh mate & been on here a while, ideally need to see the costs associated & then judge from this, as sometimes as you know it would be worth doing for a small extra expense, given that areas already out as such.
    Jan 2013
    The vvt unit is about £500 i think,if they don't have a reputation for failing then i'll leave it ....
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,758
    You won't need to change the units, there are 2 VVT units - one for the inlet cam and one for the exh cam, i have not heard of any failures with the units themselves both on the R32 or the A3 and also they are very similar units to the Bentley W12 engine and i've not come across any failures of these either (i'm an engine development engineer at Bentley).
    When i changed the chains on the wife's R32 i just did the chains and guides.
    moag's Avatar
    she's no d-turbo
    Sep 2010
    Northern Ireland
    819
    I wasnt aware that the camchain itself needed changed on these engines? Do audi not state that its a lifetime part?
    For Sale -
    A3 rear wiper motor and arm
    A3 air vents
    56plate A3 S-Line full speaker system including amp
    26,721
    Quote Originally Posted by RobinA3 View Post
    Impressive, you kept that quiet
    Quote Originally Posted by moag View Post
    You know better than to believe that lol, it was designed to be, but I think a design flaw may have been responsible.
    moag likes this.
    moag's Avatar
    she's no d-turbo
    Sep 2010
    Northern Ireland
    819
    Very true man!
    For Sale -
    A3 air vents
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,758
    Chains are designed to be lifetime however it's a known issue on the Mk4 R32 engine which shares the same engine with the A3 and TT. VW know that this is a problem as they issued a bulletin in the US about it but not over here.
    If you buy new chains from Vw the part number has changed and has been superseded which confirms that the design of the chains have been changed - not sure what the changes are (I could find out at work) but i suspect it will be in the lines of material and tolerance changes.
  1. Replies: 19
    Last Post: 25th February 2012, 23:44
  2. 16804 bank 1 lambda. replaced and still the same fault code
    By 4rings in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th January 2012, 18:26
  3. Is there a way of having an iPod lead and cd changer connected at the same time?
    By Az in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th January 2011, 10:29
  4. Replies: 9
    Last Post: 26th January 2008, 15:02
  5. S4 Timing Belt - What to do at the Same Time ?
    By mwarrey in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th June 2005, 01:03
