Sky InsuranceAH Fabrications
Results 1 to 8 of 8
    Jan 2013
    40
    Need a spare key! HOW??
    Picked up my new audi a3 last nite! Its on a 54 plate 3.2 v6 was inly given one key, just wany to jnow what i have to do i.e getting it programmed and to get the central locking to work? Help would be appreciated!
    Jonathaan's Avatar
    Diesel Power!
    Nov 2012
    Leeds
    503
    if you go to your nearest Audi dealer and take proof of identity and proof of owning the car, im sure they would be able to do one.
    Or as far as im aware you should be able to do that,
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by dalejones View Post
    As Jonathaan stated - take all your documents to Audi and they will get one from Germany. Will cost about £200 - £250 and take about a week.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,536
    theres plenty of places on the net that will supply and code a new key for far less then audi
    and they come to you to do it.
    beachbuggy's Avatar
    Surrey
    1,746
    Or speak to dan @ keysinthepost (google it) and he'll sort you out a key for considerably less than audi will, say your from the forum and you may well get a discount . Then find someone local with vagcom to program it. Audi is always a good place obviously but horrendously expensive !
    27,129
    Are you asking about getting a second key or recoding existing?
    If existing, then I assume it starts the car, so the immo doenst need reprogramming, but arent the remote locking features working currently then & does the central locking work via key in door?
    Quote Originally Posted by beachbuggy View Post
    Will he precode the immo chip?
    Also unless he has the skc then nobody can code via vcds, only remote locking abilities.
    Jan 2013
    40
    I got 1 key i just want a second as im always losing keys!!
    27,129
    Safest bet is audi tbh, expensive they may be, but when comes to coding my oem immo, I only trust them.
  1. Need a spare key...
    By stefoster in forum General Automotive Chat
    Last Post: 25th January 2013, 14:47
  2. need a spare key
    By danphipps in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th March 2012, 00:33
  3. programming spare key
    By Nel in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd September 2004, 23:15
  4. 2001 S3 spare keys
    By imported_hornet_basher in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd September 2004, 21:19
  5. Help! Advice on Spare Key please!
    By AndyMcUK in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th November 2003, 20:33
