Monster MotorsportVolks Autos
Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By mike foster
Thread: Rear wiper has a mind of its own
    Jan 2013
    Wiltshrie
    85
    My rear wiper when switched on and off does a few cycles then stops half way on the screen and some times its fine and once it has gone off without the wiper stalk being in the correct position, whats the most likely cause? stalk, motor?
    Jan 2013
    I had a motor replaced on mine for similar symptoms ,so i would say its the motor , not cheap though, £200 ish iirc
    Jan 2013
    Wiltshrie
    85
    This car is costing a fortune already lol
    Jan 2013
    Cambridge
    My oldmans 57plate A4 had this problem, took the trim panel off and found the ground corroded, so quick bit of de-corrosion at the stud and WD-40 and then that seemed to fix it, (this was saturday) so its been fine for 2 and a half days which he says is a record!
    Fossie
    Rhubarb Triangle
    3,961
    Quote Originally Posted by A3Craig View Post
    Loads of threads on the subject - try and do a search. Most likely is motor corroded inside with washer fluid. Latest motor has been modified and costs about £120 from Audi.
    Mostly affects 2005 - 2007 models and is very common fault.
    audicruiser likes this.
    Jan 2013
    Wiltshrie
    85
    That would be better on the pocket if it was just an earth, thanks, will have a look and let you know how I get on
    Jan 2013
    Wiltshrie
    85
    . Mine is 2006 so could be, will take panel off and see what I find
    audicruiser's Avatar
    Audi Heaven
    Somerset
    1,850
    You will need a motor for sure.... Mine went and was built late 2006.
    Scott
    Audi A3 Sportback 2.0T Quattro S-Line 2007 8P2
    Lava Grey, Exclusive Line Black/Silver Leather, Heated Seats, Bose, RNS-e, iPod, Auto Lights & Wipers, Interior Light Pack
    Jan 2013
    Wiltshrie
    85
    Rang audi up and for a new rear wiper motor it's £115.72, however they have it on eurocarparts for £93.60 and with 25% discount code it makes it £70.20
    Fossie
    Rhubarb Triangle
    3,961
    Just make sure it's the latest version 8E9 955 711 suffix 'E'
    Feb 2012
    Birmingham
    132
    FYI i found that Belfast Audi do a genuine motor 8E9 955 711E for £78 delivered from Ebay
  1. Rear wiper has a mind of it's own! - A4/S4 Avant
    By S3 Wannabe in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd November 2010, 20:32
  2. sunroof has a mind of its own
    By ALPINE in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th June 2008, 11:22
  3. Sunroof has a mind of its own
    By adamgroves in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th August 2004, 19:57
  4. Petrol gauge has a mind of its own
    By PaulBelsham in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th July 2004, 10:37
  5. My clock has a mind of its own
    By Kevint in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th October 2003, 12:52
