AH FabricationsSky Insurance
    Jan 2013
    Wiltshrie
    85
    Temperature guage not sitting at 90
    after the car has been running for 30mins the car still doesn't sit at 90 on the gauge and seems to fluctuate, im assume its a faulty temperature sensor, i know on some of the sensor people advise only using genuine parts is this one of them or do people use pattern ones ok?
    27,038
    Its only £20-30 from audi, so just buy oem, then you have 2 year warranty & more than likely it will work properly from the get.
    Jan 2013
    Wiltshrie
    85
    Nice and cheap, will get one order this week, thanks for your help
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    748
    Thermostats stick open a lot on these too.
    Unicorn Motor Developments. Bespoke Calibration and Remapping Services
    www.unicornmotordevelopments.com
    Jan 2013
    Wiltshrie
    85
    thanks for response, will check this out
    Jan 2013
    Wiltshrie
    85
    Do you think i could test if it is the thermostat stuck open by letting the car tick over on the drive, i know it would take a while to get to temp but would this work?
  1. Coolant Temperature Guage Not Working - Help and Advice Please?!
    By CHRIS555 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th September 2010, 22:02
  2. Oil temp guage not working
    By andy64 in forum Classic Audi Forum
    Last Post: 3rd April 2006, 18:15
  3. temperature guage probs,
    By griffj in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th March 2006, 19:09
  4. Temperature Gauge not working!!!
    By MickA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st March 2005, 08:55
  5. External temperature DIS not showing - Please Help
    By coajt in forum General Technical / How To
    Last Post: 27th February 2005, 11:54
