AH FabricationsJMB Retrofits
    Jan 2013
    Wiltshrie
    85
    Boot not shutting properly
    Hi, when i shut the boot from a height the lock doesn't catch but if i do it slightly open and keep pressure on it it shuts fine, its like the bump stops are to strong?
    27,097
    Check the seal is fitted ok, also check the lock catch flicks across manually to lock position & holds when you pull on it.
  1. A3 Boot Not shutting.
    By Jonathaan in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th December 2012, 23:12
  2. boot stuck shut, battery NOT flat.
    By BahnStormer77 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th March 2012, 17:04
  3. Door not shutting properly?
    By Bigman in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th April 2007, 11:39
  4. Drivers Door Not shutting Properly
    By myrichdad in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st October 2006, 19:17
  5. Door chime not shutting off
    By imported_TurboMan in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th August 2004, 18:16
