Badger5AH Fabrications
Results 1 to 11 of 11
Thread: Glow plugs
    dex140's Avatar
    Dec 2009
    190
    Glow plugs
    Hi over the colder weather my tdi has been rough on starting.. I have read for fault codes but no codes associated with glowpugs etc. My question do the glowpugs perish before they fail resulting in rough starting?
    May 2012
    RETFORD, NOTTS
    1,748
    I always used to remove the plug and test it on a 12v battery, it should quickly glow red hot.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Feb 2004
    Borders, Scotland
    404
    Haven't heard of perishing, in fact in my experience it's quite rare for Glow plugs to need replaced. Could it need serviced, maybe fuel filter change?
    Jul 2010
    Merthyr Tydfil, United Kingdom
    874
    Weak battery??
    Now a happy owner of an A3 Sportback S Line 170 TDI
    My Posh Golf
    dex140's Avatar
    Dec 2009
    190
    Quote Originally Posted by Vorshprungdork View Post
    Its serviced regulary by myself so sadly it wont be this i dont think
    dex140's Avatar
    Dec 2009
    190
    Quote Originally Posted by Rhyso View Post
    Weak battery??
    Possibly i will get it tested! Its weired because my tdi 140 was fine on a cold start but the 170 appears to be quite rough!
    Oct 2012
    134
    Glow plugs do deteriorate over time and fail just like any heating element. VCDS should show if any of them are beyond use though.
    Dec 2012
    23
    Quote Originally Posted by @udi A3 View Post
    Be careful with that: some glow plugs are pulsed on, and may have a lower than 12v operating voltage - so they might get fried if hooked up to a battery directly for more than a second or so.
    Regarding the OP, if the glow plug fails with a short, it will come up as an error code in VAGCOM. On my 140 TDI, all were shot. Replaced them all, and the starting got better, however the issue I had with cold starting was a lazy starter that resultet in slow turnover and therefore the ECU hesitated to inject fuel. Replaced the starter and the engine turned over 4x faster, and starts right away no matter what temp. See my post: 2.0 tdi 140 slow crank/start in cold? (Video inside)
    27,029
    Yeah the newer starters are better, I fitted a new one to each of our 8P's & the startup speed was dramatic, no word of a lie.
    May 2011
    Portsmouth
    397
    Bit of bump but trawling through old posts here as mine has a cold start issue. Plan is to replace start then glow plugs (if required) and clean the injectors also.
    Out of interest when you say the newer starters are these from third party companies or did you go direct to Audi, do you also mind if I ask the cost? I'm thinking about the £250-£300 brand new?
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    I recently had a quote for a new starter motor from Stoke Audi for £250 and there is a £72 surcharge - you get that back.
    VCDS USER
  1. 1996 A6 2.5TDi Quattro Estate Glow Plug Problem
    By mmarks in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 20th May 2007, 20:13
  2. 2.5TDi glow plug problem
    By mmarks in forum Classic Audi Forum
    Last Post: 4th April 2004, 20:16
  3. 2.5TDi glow plug problem
    By mmarks in forum General Technical / How To
    Last Post: 14th March 2004, 11:49
  4. 2.5Tdi glow plug problem
    By mmarks in forum Diesel forum
    Last Post: 29th February 2004, 20:45
  5. 1996 A6 2.5 Tdi Quattro Estate Glow plug problem
    Last Post: 4th December 2003, 19:54
