Volks AutosMonster Motorsport
Results 1 to 16 of 16
    Nov 2012
    Renfrew
    23
    Rear speed sensor change
    Hi I'm having a problem with my rear wheel sensor on my 2006 Audi A3 TDI. The esp and abs light was coming on I scanned the car with vcds and threw rear right sensor code.
    I changed the sensor lights went off ....only to come on at 50 mph ......! Same result on vcds intermittent fault on rear speed sensor.
    Could a bearing cause this error?
    Could this be the symptoms of the dreaded abs unit failing?
    What codes does the abs module throw up on vcds?
    26,776
    Cant recall if rear has the sensor plummed into the bearing housing to pickup revolutions, but if sensor is new, then for me I'd look at any debri in those areas got into where shouldnt, loom/connector or the abs ring/bearing housing, ideally need the proper log to see what the actual error is.
    Nov 2012
    Renfrew
    23
    Audi A3 1.9 tdi 8p
    The original code was
    00287-ABS Wheel speed Sensor-rear right (G44)
    003-Mechanical Failure-Intermittent
    008-Implausable Signal-intermittent
    I erased the code after fitting the new sensor and will check later to see if it is showing the same code.
    "My recently purchased vagcom vcds cable is awesome didnt realise how many things were wrong with my A4 cab....Jobs for the summer... lol.
    26,776
    Show the abs module complete log, not just the lines above please.
    Nov 2012
    Renfrew
    23
    I'll re-scan tonight and take copy of it.
    Thanks for your help.
    Aug 2012
    Aberdeen
    35
    I had a similar problem middle of last year. Turned out that the toothed rotors that generate the signal were also damaged. May be worth a check.
    brough74's Avatar
    Oct 2010
    423
    I would say its the ABS ring on the bearing, ive had a simalar problem in the past.
    S3 gone but not forgotten, now on a Golf R
    Nov 2012
    Renfrew
    23
    Thanks guys ! Im hoping its just the speedring thing and not the module.
    This is the codes i got after the re-scan
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA
    Component: ESP FRONT MK60 0102
    Revision: 00H13001
    Coding: 0021121
    Shop #: WSC 06314 000 00000
    VCID: 71ED8A85688FD090DE2
    1 Fault Found:
    00287 - ABS Wheel Speed Sensor; Rear Right (G44)
    008 - Implausible Signal - Intermittent
    26,776
    Yeah I seem to recall the abs ring is part of the bearing unit these days?
    Nov 2012
    Renfrew
    23
    Thanks for that ....i've ordered the 18mm spline bit so probably change over the bearing at the weekend weather permitting.
    brough74's Avatar
    Oct 2010
    423
    I think you need a M14 spline aswell for the caliper carrier, when i did mine on a golf it took about 40 mins a side
    Aug 2012
    Aberdeen
    35
    Well I messed up in that case. I got the whole bearing unit changed when I had the problem. Didn't know you could change the toothed rotor separately. Let us know how you get on.
    Aug 2012
    Aberdeen
    35
    Also what I was told was that if the rotor is damaged there is the possibility of re damaging the new sensors add they can be hit by parts of the rotor or debris. Either that or I want listening properly or the garage was feeding me rubbish.
    Nov 2012
    Renfrew
    23
    New bearing /hub fitted ...no lights so far .The old part was badly corroded at the back so hopefully that was the problem. Just undid the m18 spline in the center and the whole unit came off no problem no need for a m14 spline for this vehicle ....unfortunately bought one before starting the job. Not to worry ....thanks everyone for your help !!!
    if taking this job on make sure you get the same bearing diameter mine was 30mm but it also comes in 33mm diameter as I got the wrong one first time.
    26,776
    Good, glad it seems to have rectified issue.
    Nov 2012
    Renfrew
    23
    I have added some pics of the change hopefully be useful.IMG_20130202_080923.jpgIMG_20130201_113556.jpgIMG_20130201_140725.jpgcheers
  1. Audi a3 2.0 tdi ABS Wheel Speed Sensor; Rear Right (G44) Implausable signal
    By chrisy t in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th December 2012, 21:04
  2. Left rear speed/abs sensor removal.
    By leecool in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th August 2012, 16:33
  3. Rear wheel speed sensor
    By 666markyboy in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th January 2011, 23:29
  4. Aftermarket Rear Parking Sensors
    By hfu in forum Detailing
    Last Post: 15th April 2004, 14:15
  5. Aftermarket Rear Parking Sensors
    By hfu in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th March 2004, 13:02
