AH FabricationsSky Insurance
Results 1 to 38 of 38
Like Tree1Likes
  • 1 Post By tdi-man
Thread: A warning to those who want LED number plate lights
    Dec 2010
    370
    Ive seen on here a thread linking to an ebay seller who sells LED number plate lights that wont give an error code. I decided to buy them and fitted them with no problems - they looked fantastic, a big improvement in look and in light!
    That was 3 weeks ago and today I took my car for its MOT - it failed :-( Reason being that my number plate lights had stopped working! I couldnt work out why so decided to just get some new original bulbs but they wouldnt work either, I then checked all the fuses and they were fine. I then spoke to my brother who works on VW/Audi and he said it is likely that the computer would have turned the lights off as they are not suitable and that I would need to use VCDS to remove the fault code and get the lights working again. Luckily for me he has that software and he was spot on - error code came up on his laptop and with the click of a button the lights were sorted again (using original bulbs). If I didnt know someone with that software then I could have been looking at a trip to Audi to get it sorted.
    Certainly wont be putting the LEDs back in thats for sure!
    Sep 2007
    Swindon Wilts
    170
    I've had a problem with non error leds for the sidelights - intermittently they'd work. I contacted the ebay seller a he has sent me a different sort...dont think i'll bother with them now!
    Jan 2012
    SW London
    751
    Uve just been unlucky. Contact t8ups if u want some proper LEDs that wont give u problems.
    2006 Audi A3 2.0 TDI S-Line 8P2 PD170 - Dolphin Grey Metallic - The problem child
    1994 VW Golf VR6 - Mystic Blue - The money thief
    VCDS User
    Mr. B's Avatar
    English...not so good
    Jan 2012
    Bristol
    870
    I gave up with these as well, too much hassle
    Dec 2010
    370
    Quote Originally Posted by Sidhu88 View Post
    Is that long term? They worked perfectly at first but over time caused problems.
    The warning still stands though - if people buy them, they should make sure they work a few weeks later before purchasing or they could end up with a nice bill at Audi!
    Jun 2011
    Wellingborough
    1,126
    if you turn the car off, put normal bulbs back in and swich the ignition back on then it will work again, dont need vcds to swich them back on, the error will go from your dash but the fault will be logged in VCDS with a date and time of when it 1st occoured.
    why not purchase the OEM Audi LED's they sell?
    Trups
    Bi Xenon Projector kits starting at £79.99 per pair.
    EM Tuning Lighting.
    Dec 2010
    370
    Quote Originally Posted by t8ups View Post
    Trups
    Not the case. We disconnected the battery to see if it would work as my brother didnt have his computer with him. It made no odds - had to use VCDS to solve it.
    tdi-man's Avatar
    Jul 2009
    1,587
    i use genuine a5 number plate bulbs in mine had um in for over 6 months no probs
    dancupra225 likes this.
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs / Oil catch can
    233 bhp - 309 ft lb - 419 nm
    FLYWHEEL + HELIX CLUTCH KIT FOR SALE
    ryanstewart9's Avatar
    Sep 2009
    Surrey/Hants/Berks
    438
    Quote Originally Posted by tdi-man View Post
    +1
    "If you ain't first, you're last!" - Ricky Bobby
    2008 A3 S-line 2.0 TDI PD140 (Pre-facelift)
    Jan 2011
    120
    Quote Originally Posted by ryanstewart9 View Post
    +1
    Have you got part numbers please
    Sep 2009
    Surrey/Hants/Berks
    438
    Pretty sure it's:
    4H0 943 021
    Jun 2011
    Wellingborough
    1,126
    Pretty sure it's:
    4H0 943 021
    and 4H0 943 022.
    Trups
    EM Tuning Lighting.
    Turbo jay's Avatar
    Leather repair specialist
    Jul 2012
    North west
    547
    What's the difference between the two part numbers ?
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,073
    Quote Originally Posted by Turbo jay View Post
    Left and right.
    they come as a complete unit, cost around £20 for the pair.
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
    Turbo jay's Avatar
    Jul 2012
    North west
    547
    Ok cheers danny, are they plug and play?
    downtothebone's Avatar
    Mar 2012
    Wimbledon
    195
    OK, so before we all start patting each other on the back ... those of you with late 2010 and early 2011 cars with the BCM module version 615 ... these OEM modules won't work. Use Search.
    Boon's Avatar
    Sep 2012
    South East Kent
    338
    I used just plain simple LED bulbs without canbus & hard wired one original standard bulb inside the boot lid. They will only stop working when the standard bulb blows & it'll throw the error up but will be a simple fix
    Acheron's Avatar
    Jan 2012
    South Africa
    263
    Quote Originally Posted by downtothebone View Post
    +1
    Those cars equipped with that particular version cannot use the OEM LED units as the CANBUS system throws a wobbly and the module version does not support coding out the monitoring of the circuit via VCDS.
    Current: 2010 Audi S3 Sportback S-tronic
    Ex: 2007 Audi A3 Sportback - 2.0T DSG
    Ex: 2008 Opel Corsa OPC
    Ex: 2004 Opel Corsa Lite
    Ex: 1978 VW Beetle
    flying oyster's Avatar
    flying oyster
    Jul 2009
    wimbledon
    545
    ive had t8ups lights in mine with no problems as have my mates since audis in the park wouldnt use anyone else
    S3 8L ming blue westys old car shed loads of mods
    Jan 2013
    40
    Wot are the t8ups?
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,621
    Quote Originally Posted by dalejones View Post
    Wot are the t8ups?
    lol... t8ups is a member here, sells bulbs and posted above.
    2009 A3 SB 2.0T DSG S line
    RYes3's Avatar
    Apr 2012
    Cheshire
    730
    Anyone know if there is any LED's that will work on a 62 plate RS3? Before anyone shouts I have searched, there is so much conflicting information out there now though!
    2012 RS3 Ibis White | Black Styling Pack | Black Roof Rails | Bose | Cruise | Tyre Package | Privacy Glass
    JS3
    Oct 2011
    209
    I tried the A5 units with no luck. Couldnt be coded to work apparently.
    I have a 2010 S3.
    2010 S3, Sprint Blue, S-Tronic, RNSE, Cruise Control, Interior Light Pack, Upgraded LED Interior Bulbs, Heated Seats, Hill Hold, Boot Buddy, Fog Turn Lights, Revo Stage 1, De-Wipered
    Ben S3 8P3's Avatar
    Jul 2012
    Bury//Manchester//Leeds
    313
    Ive got a 2009 S3, what is the situation with these? Would the A5 LED's work?
    ApolloS3's Avatar
    Jul 2012
    Newport, South Wales
    73
    Quote Originally Posted by Silverfoxzzz View Post
    I just bought the genuine audi LED's straight from audi, cost £30 for both, threw an error at first and they were off and on, but that was because the original screw was slightly out, bought some hex screws and screwed them in as far as possible, lights now work perfectly with no errors, never needed software.
    Wicked666's Avatar
    Feb 2005
    Leeds
    565
    I have some trups LEDs but not sure how to take existing bulbs out. Is it just brute strength or are they special screws and I need to get replacements?
    S3 Sportback
  28. #27
    Wicked666's Avatar
    Feb 2005
    Leeds
    565
    Ignore the above. Found this. It is just my screws that are held in really well.
    http://tadasauce.wordpress.com/2009/...rior-lighting/
    S3 Sportback
  29. #28
    Jack_tdi's Avatar
    Mar 2012
    Cumbria, England
    281
    Quote Originally Posted by roston100 View Post
    Worst case scenario you could of reset it with a v gate 450. I have one and it was about £40 from amazon (cheaper than any diagnostic test at a garage) and that will reset any fault code in any enabled module.
  30. #29
    Mar 2012
    Wimbledon
    195
    So I now have LED units (I think the same referred to by the OP - each unit has 6 LEDs) in my car - all working fine for now and first time I've been able to get plug and play LEDs to work without errors. I have the BCM 615 version. Lets see how long they last.
    APR Carbonio CAI / Eibach ARBs / BCS 3" Downpipe & Sports Cat / H&R 50mm Springs / APR Stage 2 / WALK / Forge Quickshift / RNSE / Forge 330 Big Brake / Carbon Grab Handles / Whiteline F&R Adj Drop Links / R8 Oil Cap / Porsche Coolant Cap / APR Intercooler
  31. #30
    Jul 2011
    32
    Quote Originally Posted by ApolloS3 View Post
    The main problem with fitting the new Audi A5 led's in, is the contacts which needs to be bent out to match (or there abouts) the original one's.I have a feeing they are only just making contact - hence the extra tightening of the screws.
  32. #31
    Kaza's Avatar
    Mar 2013
    Chatham, Kent.
    88
    Quote Originally Posted by RYes3 View Post
    My thoughts exactly. I have recently purchased a TDI Sportback (2010 plate) and one thing I would like to do is to change the number plate bulbs to a 'whiter' light, but have not seen many normal bulbs that would provide this, just LED'S. Even 'error free' canbus compatible bulbs don't seem to work as they still bring an error up on the dash. I have also searched but as you say, there doesn't seem to be a definitive answer.
  33. #32
    Feb 2011
    Preston
    64
    There is a fix fella, will find my original post but the oem leds and a number plate wire does the trick.
    Quote Originally Posted by Kaza View Post
  34. #33
    Feb 2011
    Preston
    64
  35. #34
    Kaza's Avatar
    Mar 2013
    Chatham, Kent.
    88
    Thanks for that very helpful!
    FOO: Phantom Black TT (211ps) S-Line
  36. #35
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,916
    and 4H0 943 022.
    Trups
    i know yes i know old thred
    but t8ups do the A5 leds fit the a4 ?
  37. #36
    pon5on's Avatar
    Jan 2013
    Oxfordshire
    9
    I've read pretty much all the number plate LED threads on here, tried all possible combinations and these are my findings.
    2009 and earlier seem to work with no errors, be it bulb replacements in OEM housing, or complete unit replacements bought from eBay vendors.
    2010 and 2011 models require load balancing on the circuit due to VCDS software used unable to code out LED use. This link has a manufactured resistor using OEM male and female connectors to bridge the circuit. No cutting, no splicing, just plug and play. You will need to remove your inner boot liner to fit this:
    Adapter plate LEDs Audi A4 B6, B7 / Audi A3 8P-39298-1
    I know it works because I have one, and it's for sale for £30. It cost me £35 after delivery from Germany.
    If you have a 2012 model like me, then you code out the LEDs, like Trups from this forum has done for me. It's a 2 minute job, just a tick in the correct box on the software.
    Job done. The hard way.
    2012 A3 2.0 TDI Sportback Black Edition in Panther Black.
    Mods: Black rings front and back, black S Line badges on front wings, LED number plate lights.
  38. #37
    Breezey's Avatar
    Hexxagon Champion
    Mar 2010
    Bridgwater
    430
    Does anyone know if the genuine A5 ones will work on a 2004 A3 ?
  39. #38
    Jan 2012
    1,599
    Massive thread here on the subject mate - Original Audi number plate LED's that fit the A3 8P - plug & play!
  1. led number plate lights
    By mitch_h_88 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 29th October 2010, 22:50
  2. AUDI A3 LED NUMBER PLATE LIGHT REPLACEMANTS
    By philipjmarshall in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th June 2010, 21:31
  3. led number plate lights
    By AARON77 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th April 2010, 13:40
  4. LED number plate Lights....help!!!!
    By V16 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th March 2010, 21:07
  5. New Type LED Number Plate Lights
    By david_phillips95 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd December 2009, 14:26
