EM TuningChris Nott
    Jun 2012
    49
    JBS Auto Designs & Darkside Developments dpf and egr delete packages
    Any had any of these done on there cars and what are your views on them.. any better places to go.. dont want dpf gutting i want a new pipework by the way.. i know it says 210-240 bhp depending on current mods..... anyone know the mods needed to take it to 240 bhp
    thanks in advance
    347
    347's Avatar
    Sep 2006
    223
    hi there , my previous A3 was a 170 tdi .
    I had it remapped , miltek big bore down pipe (dpf delete) dpf delete software remap , miltek non resonated full system , all done by JBS auto designs.
    Initially I had the "wild" map , found it very annoying to drive after the novelty wore off, barely touching throttle gave 100% throttle .
    Car was never rolling roaded as it was not included in the price ! and when mentioned said the rolling road was out of action.
    so no power figures are available for my car.
    That said once I had the remap redone by JBS as "mild" I had no other issues , car drove well and certainly had loads of torque.
    in fact too much , 6 months after remap the clutch started to slip so that was replaced with a uprated sachs clutch and a standard dual mass flywheel was also fitted .
    For a tdi the car was quick and did push you into the back of the seat , had a couple of duals with other cars and thet really didnt pull away that much.
    I saw no real improvement in mpg , not that i was looking for that , averaged 45 mpg over 25 mile A road drive to work.
    was a little harder on front tyres , too be expected.
    car passed 2 mot's in tuned state with no issues , and was remapped at 56k and was sold at 87k .
    one other point to note it did belch black smoke (soot) on hard acceleration , so it is obvious the dpf is removed , and depends if you like a dirty rear end , ooh errr !
    the dpf delete pipe certainly made the turbo spool up a lot quicker , and you could hear this as well as feel it.
    hope that is of some help.
    john
    2010 2.0 Tfsi BE ibis white DSG , now sharked
    Jan 2012
    105
    I would imagine 240 BHP would need an uprated clutch (pricey). Might be a better idea to start with a quattro 170 for that much extra power.
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    683
    You're not going to get 240 on the std injectors, they don't have a lot of head room. A lot of power quotes are a little on the optimistic side. We say 205bhp, and with that it feels very quick. After that it's turbo, injectors, exhaust etc and it's not that nice to drive. Much better going for the TFSI if you want more power.
    Rick
    Unicorn Motor Developments. Bespoke Calibration and Remapping Services
    www.unicornmotordevelopments.com
    tdi-man's Avatar
    Jul 2009
    1,588
    ive deleted the egr cooler on my car using there system quiet an eay job to do as long as the egr is mapped out your ecu.
    im on 213 bhp with a few mods
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs / Oil catch can
    233 bhp - 309 ft lb - 419 nm
    FLYWHEEL + HELIX CLUTCH KIT FOR SALE
    ElliottB's Avatar
    Audi A3
    Nov 2011
    Hull
    143
    JBS AUTO DESIGNS & DARKSIDE DEVELOPMENTS DPF AND EGR DELETE PACKAGES
    Darkside devlopments are absolutly amazing at what they do, they have done alot of engine work on my car, wouldnt take it anywere else now. I will be going 80 miles to them just for a service!
    Audi A3 2.0 TDI - S3 Intercooler - Darkside Developments Hard Pipe Boost Kit - EGR Delete - Milltek Non-Res Decat Exhaust System - Performance -Torque Custom Remap 187BHP + 335lb/ft
  1. remap dpf and egr gone
    By buggy_666 in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 13th January 2013, 09:42
  2. DPF and EGR removal service
    By Rick @ Unicorn Motor Dev. in forum Unicorn Motor Developments
    Last Post: 15th June 2012, 14:49
  3. JBS Auto Designs Open Day
    By JBS Alec in forum Smaller (Local) Events
    Last Post: 22nd September 2008, 18:36
