JMB RetrofitsSky Insurance
    bagey's Avatar
    aud you do !
    Newcastle
    198
    rear led light not working
    hi all, i upgraded my rear lights to led 09 ones last year and yesterday i got an error off the left one and now the led part isnt working . anyone got any ideas how to fix ? . when i took it apart i noticed a bit of water in the connectors , so i dryed them out with hairdryer but that hasnt worked ? any help would be grateful .
    27,114
    This is why I dont use adapters on these installs & wire them in as per factory, hassle coupled with no working lights it worth the extra cost.
    You'll need to remove, clean up connectors or any corrosion & water, then reseal, check fuses & any voltage on wires, also check for any codes thrown.
    bagey's Avatar
    aud you do !
    Newcastle
    198
    ok nige , appreciate reply
  1. Rear fog light not working.
    By Gstar51 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st May 2012, 18:18
  2. Audi a3 05 rear numberplate lights not working help
    By andy1acars in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th April 2011, 18:50
  3. Rear Reg plate light not working
    By Spec in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th August 2009, 15:25
  4. UK reg 54 plate 2.4 V6 rear number plate lights not working - CAN Bus issue?
    By A6fella in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 9th December 2008, 14:29
  5. Rear door light not working
    By ang12el in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th December 2007, 09:12
