Results 1 to 14 of 14
    Jan 2013
    57
    Tuning option for the 2.0 pd170 tdi
    Hi
    Just trying to put some info together on tuning options..
    Car has had dpf, egr removal and supposed remap, goes well but not 100% sure on the map tbh..
    So what are the limitations on turbo , clutch and engine in general?
    Torque, Torque, Torque
    27,126
    Who mapped it & why unsure?
    RedDejavu's Avatar
    Feb 2011
    Bracknell
    1,485
    stage 2 is probably top limit for the turbo, but tbh not many people went any further as it gets very expensive for stage 3
    Be patient. English is tough.
    Now:
    61 Audi S3 BE S-Tronic Ibis White: Build Thread.
    / Black Edition pack (SatNav, Bluetooth) / Parking Sensors / Tinted windows / piano inlays and finish / Cruise Control / Interior light pack /
    /Mods: REVO Stage 2+: Revo Intake / BCS Powervalve TBE system / LOBA HPFP / Crystal Clear H11 FOGS / Black roof + spoiler vinyl wrap / H&R Anti-roll bars / Superpro ALK /
    Jan 2013
    57
    Map was done be previous owner along with dpf and egr through a company called mr tyre up in nottingham.. I have the receipt for work totalling £800 for map and dpf egr removal.
    As I understand it the dpf is restrictive and problematic so it got taken out and mapped out..
    Whilst the car goes well, I just think for a remapped car it should have more grunt.. Maybe its just me, need to get it on RR to see whats what.
    Jan 2013
    57
    Quote Originally Posted by RedDejavu View Post
    Yeh, im not looking to go crazy just wanted to see options, maybe 250bhp and buckets of torque depending on accessability
    27,126
    You sure you're not referring to a tfsi/petrol as havnt heard of a stage 3 tdi 170 upgrade, be interested to see that data.
    Jan 2013
    57
    Gave it a little clean today..
    Baza1819's Avatar
    Jan 2012
    Sunderland
    254
    220' is about the most you should take it - otherwise turbo / clutch etc will be at breaking point.
    2.0 tdi 220 Quattro.....
    Bigfish tuning remap, S-line half Leather heated seats, Bose sounds, Elec' fold in heated mirrors, tyre pressure monitors, Charcoal roof linning, Mfsw,phone prep, 18" Speedlines, Dual climate, total open/closure remote windows,L.e.d rear lights, Ch/Lh lights,puddle lights,Cruise Ctrl, Ambient Interior lighting, footwell lights & it's a Quattro......
    RedDejavu's Avatar
    Feb 2011
    Bracknell
    1,485
    hybrid/bigger turbo + uprated injectors?:]. But who would've spent so much to get extra 30-50 bhp.
    Now:
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    Stage 2 can see you with around 220bhp & 330+lb/ft of torque. Why you'd want any more than that is beyond me, I'm breaking traction at 4K rpm with decent tyres & Im only on stage 1 at the moment. Also the clutch is usually right on its limits with the stage 2 so that's another expense to consider.
    There is a stage 2+ option which is way too smokey for road use, & a stage 3, but as mentioned before this means modified injectors hybrid turbo etc.
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    Jan 2013
    57
    Quote Originally Posted by max69vk View Post
    Thanks for your input..
    Is your 2 or 4 wd?
    Jul 2007
    London
    3,256
    Quote Originally Posted by the obese penguin View Post
    Hi
    You will need a bigger turbo for 250Bhp, larger nozzles as well. See Darkside Developments for their GTB2260vk turbo kit and tubular manifold to fit transverse engines !
    FOR SALE:
    Old-Boy-Racer
    What are the BHP Torque figures from the tuner? I have a remap from R-Tech for £400 (inc returning customer discount of £100.) so £800 sounds steep and should be excellent work. Mine now has 205 BHP and 340 torques. Remember BHP gives you top speed and torques give you acceleration/grunt. I can spin the wheels in 3rd and had to upgrade to Sachs clutch to cope. It's not quick like my S4 was but its pretty good and a major upgrade on standard. Much more driveable and great fun when you want to 'press on'!
    I really don't need any more unless I wanted to do track days and then I'd have to start looking at suspension and driveline upgrades, or it wouldn't cope.
    If the tuners are any good they should be prepared to put it back on the rolling road and check it out for you.
    Jan 2013
    57
    I dont have figures as there is no print out for that... The reciept is a bit vague, just says egr removal dpf removal and remap, as said for £800... The company that did the work are 300+ miles away..
    Need to find a 4wd RR down in the southwest to get it power tested..
  1. Plug and Play Tuning for the new 3.0 TDi 204 and 245ps
    By ABYSS in forum Diesel Tuning UK
    Last Post: 7th May 2012, 15:54
  2. Plug and Play Tuning option for the new 2.0tdi 177ps
    Last Post: 7th May 2012, 15:52
  3. Strut brace & other options for the S3
    By warren_S5 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th July 2009, 16:32
  4. Does Quattro option alter the suspension? SB 170 TDi SPT
    By theaddamsfamily in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th January 2008, 20:09
  5. tuning options for a3 quattro?
    By ak_quattro454 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th November 2006, 11:48
