Chris NottBadger5
    May 2011
    A3 TDI S-LINE 170 SP 2009 BOSE SYSTEM DOESNT SOUND RIGHT ??
    Right ive got an A3 on a 2009 which has the bose system installed but it doesnt have the same quality as my previous A3 on a 2005 which had the bose so i kinda know what im expecting to hear which to me is one of the best factory installed car stereos ive heard obviously a debatable fact now ive read the numerous bose threads but still.it seems to be a problem with the drivers side speaker/speakers because if i chance the balance to all left theres plenty on base up front and if i change it all right it missing some vital base and cant feel the same thump comming form the drivers door speaker but need some one to tell me /have a look and work out if its just the door speaker and or what i need to get it sounding right ie a good audio specialist in the leicestershire/northamptonshire area thanks guys
    monopole's Avatar
    limboitis
    Oct 2012
    County Antrim
    305
    ^ see if you fit them in somewhere
    +incoming (64/Sep 1st) S3 (300) Sportback S-Tronic Quattro Daytona Grey
    -outgoing (63) A5 2.0TDI (177) Coupe Black Edition S-Tronic Quattro Phantom Black
    VCDS Location: NI (County Antrim)
    - (62) A1 1.6TDI (105) Sport Manual Sportback Brilliant Black
    - (62) S3 (265) Sportback Black Edition S-Tronic Quattro Phantom Black
    - (58) TT Roadster 3.2 V6 (250) S-Tronic Quattro Phantom Black
    27,073
    The sub is actually in boot left handside, but ideally need to remove door cards & swap speakers across to see if the problem moves.
    I'm sometimes up that area so could remove it all, swap across & test, take a few hours to strip down & swap across, test & put back, but ideally be good to have a spare speaker at same time to install should yours be faulty, but if it does fix the problem, would the oem system be good enough for you, is the question.
    May 2011
    sorry monopole get bit carried away sometimes!thanks nhn,thats sounds like what i would need to do and after a few more hours of messin around i am pretty sure its the drivers side door speaker so where would be the best place to get a bose replacement from and any idea what the part number would be??really dont think id be happy with the oem system.
  1. 2007 A4 2.0 TDI S-LINE 170-WHY AN EXHAUST ON EACH SIDE?
    By SWILKO in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 28th July 2012, 21:31
  2. 2.0 tdi s-line 170 bhp running problems help because Audi main dealer CAN'T
    By DirtyDiesellee in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd July 2012, 18:50
  3. Replies: 1
    Last Post: 28th November 2011, 19:26
  4. Quattro or FWD A3 170 Tdi S Line?
    By Smithymartyn in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th August 2011, 13:29
  5. S-Line 170 TDI or Sport 170 Quattro
    By Davidb67 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd October 2007, 09:02
