Just after a bit of advice will I be ok with 9x19 bentleys et 41 on my 8p s3 I'm being told the offset is wrong although I'm currently on Helios which are et45 or 46 but only 8.5 wide will the bentleys be much different figment wise
Im running some 9x19 et 52 s6 wheels with 5mm spacers a little tucked with no issues, so like BradHatton said they will sit flush and perfect. I'd say your probably better going with 215/35/19 if you don't mind a bit of stretch.
