Hi Chaps,
Really hoping you can shed some light on my problem as I'm pretty stumped at the moment!
The other evening my A3 wouldn't start, can only presume the diesel had frozen as it was a very cold evening.
Anyway got a lift home from work and the next morning charged up the battery and she started up no worries... Great! But the evening before trying to start it I pretty much flattened the battery.
The traction control light is now on. I got our diagnostics system on it and it came up with the fault codes about the steering angle sensor having no plausible signal and also ABS control module no signal/ no communication.
I had a new windscreen fitted earlier on the same day but is there anything under the skuttle that would effect the ABS? Can only presume at the moment that I've got water in a sensor or in the steering rack gator.
Hope that makes sense and someone can help!
