Sky InsuranceVolks Autos
Results 1 to 11 of 11
    Jul 2012
    Shropshire
    32
    Which brake fluid?
    Simple question - which brake fluid should I use for my standard 2005 A3 8P 2.0l TDi?
    I presume 1 litre of Dot 5.1 would be ok?
    Thanks everyone
    wesmaster's Avatar
    Apr 2012
    Oxfordshire
    291
    I would use DOT4 ESP, otherwise problems with ABS unit.
    Oct 2012
    Fife
    59
    No No No. Use Dot4
    Oct 2012
    Fife
    59
    Quote Originally Posted by wesmaster View Post
    Beat me to it!
    Jan 2012
    powys
    59
    from what i understand if your car is designed to have dot 4.1 then that is what should be used. thay cant be mixed
    dot 5.1 is more for race use,and has a higher boiling point also you may need to replace your brake hoses under the arches to steel bradied becouse the standard ones would swell becouse dot 5.1 has less give, therefore expanding the week point when the brake is pressed.
    thats what i understand. someone else m
    wesmaster's Avatar
    Apr 2012
    Oxfordshire
    291
    Quote Originally Posted by GuyJ View Post
    Beat me to it!
    Had the pressure sensor issue?
    Jul 2012
    Shropshire
    32
    Thanks for all the replies! Fairly conclusive - I shall get some dot 4 instead. Thanks again everyone.
    JPK
    May 2012
    278
    Rather than starting my own thread. It's time for a fluid flush and change on my A3. For 'fast road' use, just use genuine VAG dot 4 fluid? Have stainless lines and new rotors and pads going on at the same time but I've read that ABS/ESP units dont particularly like race fluids like Motul RBF660 etc? OEM holds up well in most circumstances?
    2005 A3 2.0T DSG Oettinger Body Styling, 19" RS5 Reps, APR Stage 1, Forge Twintake, Remus catback, BSH PCV Fix, 034 Motorsport Mounts, WALK, Whiteline bushings (F&R), Whiteline RSB, Whiteline BSK, Whiteline adjustable end links, H&R Sport Cup Kit, Stoptech Drilled Rotors, Hawk Pads, Tyrolsport stainless lines, Tyrolsport Calliper bushings, Tyrolsport DeadSet Subframe kit.
    Pushing the limits..
    Jan 2011
    Australia
    1,314
    Add Sevv on Facebook
    is Motul RBF660 okay to use ? i just order 1.5ltrs
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Dot4 a must
    Jan 2011
    Australia
    1,314
    Quote Originally Posted by MrLapou View Post
    Dot4 a must
    so what does it basically do to the ABS unit ?
  1. Which Brake Fluid
    By Pat in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd October 2007, 12:12
  2. which brake fluid?
    By Aky in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st June 2007, 06:55
  3. Which Brakes to upgrade an S3?
    By dbm in forum Handling
    Last Post: 7th August 2003, 09:10
  4. WHICH BRAKE PADS FOR S3??
    By dans3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th July 2003, 07:59
  5. Brake Fluid
    By AL_B in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st January 2003, 23:39
