Chris NottMonster Motorsport
Results 1 to 13 of 13
    Oct 2012
    Sweden
    Height from ground to wheel arch
    Hi
    Just fitted Eibach Pro and now I have aprox 66 cm from ground to wheel arch. Before I had 68 cm, hopefully it will drop a little bit more after a couple of miles.
    It would be interesting to hear your numbers.
    Hyosung's Avatar
    Jan 2013
    24
    If you have an A3 sport edition, I believe you take off 15mm off the height the springs say they will lower your car by.. As the The springs work off of the stock ride height and the sports come 15mm lower than stock.
    I would suggest you go for the Eibach sport-line i believe its 40mm in the front lowered and 50mm in the back which works out 35 and 25..
    I believe the Eibach pro is 35mm lower isn't it? which works out at 20mm front/back which = the 2cm difference you are seeing.
    Oct 2012
    Sweden
    Mine is not sport edition, it is a Sportback 1.6 TDI (2012) with no special package. They should have dropped the car with 30mm, but I am missing 10mm. But is no big deal, I am pleased with the drop.
    Hyosung's Avatar
    Jan 2013
    24
    Oh well, give the springs some time to wear in, you can expect another 10mm drop eventually. You may notice the front right drops first due to your weight being there but eventually they will all wear in
    MTRL's Avatar
    Split Grill!
    Nov 2011
    463
    So the eibach sportline springs drop more at the back than they do at the front, does this not give a reverse rake?
    I have standard sport springs and these sound like they would give just the right drop of around 35mm
    ps....^^^ Whats the dancing signature all about?
    ....................I'll make a build thread one day.
    Hyosung's Avatar
    Jan 2013
    24
    I didn't think they did, but after reading another thread on this forum of someone who bought sportlines, apparently they don't drop the same front to back, don't quote me on it though.
    ps... Shes hot.
    EDIT:
    This is what it looks like on the 50/40 sportline springs
    Eibach Sportlines 40-50mm on a 2.0tdi sportback
    Went and did some detective work and yes they lower more on the front than the back.. This is for the Sportback though.
    Eibach Sportline Lowering Springs for Audi - larkspeed.com
    26,716
    Yeah let them drop fully, then assess if low enough.
    MTRL's Avatar
    Split Grill!
    Nov 2011
    463
    I think the drop will be just right for me, Found this pic:
    Sportline springs fitted
    Doesn't seem to have reverse rake. Think ive found the ones I need.......
    chris.vincent3's Avatar
    Apr 2012
    UK, Portsmouth
    564
    Noone considered H&R's? I went for them as i could get them from my local Euro Car Parts supplier. And they give my Sport a great even drop, exactly what i was after.
    MTRL's Avatar
    Split Grill!
    Nov 2011
    463
    Do you have a pic of your stance? Thanks,
    Apr 2012
    UK, Portsmouth
    564
    Quote Originally Posted by MTRL View Post
    Go on then! :P
    BEFORE
    AFTER
    MTRL's Avatar
    Split Grill!
    Nov 2011
    463
    Sold
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,146
    I opted against the H&R because the 50mm front/rear drop gives a bit of reverse rake. Went for eibach sportlines as the 50mm/40mm drop gives a nice even wheel to arch gap all around. Also eibach aren't as stiff as H&R.
  1. URGENT: Smoke coming from drivers wheel arch
    By Brido1888 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th July 2012, 09:53
  2. grinding noise from wheel arches.
    By Jonesy in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd July 2007, 16:25
  3. Rear Wash Wipe, Water leaking from wheel arch!
    By Gajjii in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th July 2006, 01:13
  4. Wheel arch pics
    By imported_mustwin1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th August 2004, 13:08
  5. Funny noises from my S3 (Wheel bearings?)
    By comdw in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th September 2003, 09:45
