AH FabricationsVolks Autos
    leeds2592's Avatar
    Apr 2012
    Leeds
    996
    Engine Management Light + Fault Codes - Help
    Hi all,
    The other day my Engine Management Light came on so I hooked up my VCDS, cleared the fault and went for a drive to see if it would come back on again. It did after 5 mins of driving. Car drives no different, however it does seem to be using more fuel (Unsure if this is related).
    Anyway, the codes are below and I just want to know if anybody has any info on these or how to get it sorted?
    Can post full scan if required.
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 06F 906 056 FQ HW: 06F 906 056 EK
    Component: MED9.5.10 G00 9503
    Revision: 69H03--- Serial number: AUX7Z0F8FNE00U
    Coding: 0000072
    Shop #: WSC 06314 000 00000
    VCID: 7DF7C5E8246C07F04A3
    2 Faults Found:
    000010 - Camshaft Positioner (Bank 1 Intake)
    P000A - 008 - Slow Response - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 113985 km
    Time Indication: 0
    Date: 2013.01.08
    Time: 09:36:35
    Freeze Frame:
    RPM: 760 /min
    Load: 24.7 %
    Speed: 46.0 km/h
    Temperature: 45.0°C
    008213 - Intake Manifold Flap Position Sensor (Bank 1)
    P2015 - 008 - Implausible Signal - MIL ON
    Freeze Frame:
    Fault Status: 11101000
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 114009 km
    Time Indication: 0
    Date: 2013.01.08
    Time: 13:35:18
    Freeze Frame:
    RPM: 3400 /min
    Load: 14.9 %
    Speed: 92.0 km/h
    Temperature: 72.0°C
    Readiness: 0000 0100
    Thanks in advance
    Black 2007 2.0 FSI Sport
    2011 Glossy Black RNS-E |AP Coilovers | 18" 7 Spoke OEM BE Alloy Wheels | H&R Trak+ Spacers 8mm (Front) 12mm (Rear) | MY11 Rear Lights | S Line Spoiler | Retrofitted MFSW | Retrofitted Cruise Control | Interior LED Light Pack | OEM LED Numberplate Bulbs
    Jun 2011
    Great Melton Norfolk
    1,340
    Did you go into engine readiness and reset the MIL ?
    Fossie
    Rhubarb Triangle
    3,961
    leeds2592's Avatar
    Apr 2012
    Leeds
    996
    Quote Originally Posted by gen.heinz guderian View Post
    I've not done that no, I've just gone through the Autoscan way and cleared the codes. How do I go about doing this? I'm pretty new to using VCDS.
    Yeh, I've had a read of that but it's all a bit too technical for me. Getting camelt done in the next couple of weeks so may leave it for the garage to have a look at.
  1. Replies: 2
    Last Post: 20th March 2012, 22:35
  2. Engine management light is on, HELP!!!
    By evilbane in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd December 2011, 10:30
  3. Engine management light on with fans running and 2 fault codes. HELP?!
    By Crunch in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th September 2011, 12:22
  4. Engine management light on, help me help a friend!
    By Prawn in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th September 2007, 14:47
  5. Help Engine Management Light On
    By taj in forum TT/TT-S/TT-RS Forum
    Last Post: 13th January 2005, 20:07
