Volks AutosChris Nott
    Sep 2009
    98
    Neuspeed pipe with itg filter
    Why hasn't anyone done this after researching cai it seem itg and revo come up as favourites but all I can see the difference between the itg and revo is to many joins in the itg where the revo is more flowing which led me to look back at the neuspeed it has no joins either is this possible to use with a itg filter or is it simply a diameter issue
    just a thought could save 100 squid
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,794
    I have thought about it, diameter issue would be an easy fix but the ITG filter is expensive for relatively little to no real gain, might aswell be using the Neuspeed.
    Neuspeed is washable too. I got an equivalent filter for £10 and quality seems quite good too!
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    Jan 2013
    159
    I am looking at a similar setup on my S3.
    What was your outcome and where did you buy it?
  1. TID engine cover with ITG CAI
    By blackcruiser in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th December 2009, 23:11
  2. 2.0tdi quattro 140 oil cahnge only at 40,000 with longlife filter??
    By pi quattro in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th October 2009, 11:30
  3. Coolant pipe with heat shield
    By S3mad in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th August 2008, 21:33
  4. help with oil filter...
    By cjhill in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th December 2006, 16:14
  5. Engine pipes with valves
    By rraghvani in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th September 2006, 14:22
