Volks AutosEM Tuning
Page 5 of 8 FirstFirst 12345678 LastLast
Results 161 to 200 of 304
Like Tree31Likes
Thread: 15Degrees-North S3 turbo Race Car build
  1. #161
    coreythorny's Avatar
    Mar 2013
    Leicestershire
    425
    I'm in love
  3. #162
    Dec 2012
    Peterborough
    176
    Hi Alex
    How much is the quaife and who is best for fitting?
    Mark
  4. #163
    Dec 2012
    Peterborough
    176
    Quote Originally Posted by coreythorny View Post
    I'm in love
    I hope with the car and not me ROFL.
    I am SO EAGER to get this beast out on track and start putting some vids up of my progress.
  5. #164
    Mar 2013
    Leicestershire
    425
    Quote Originally Posted by 15Degrees View Post
    not unless you come with the car
  6. #165
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,392
    Hi Alex
    Mark
    The Quaife is about £660 plus VAT and fitting on top.
    Any decent VAG tuner should be able to fit one,so your local guys would be OK for the job.
    I remember you asking about gear kits.....this may also be of use......
    http://www.sqsracing.com/produkt/179...petition-gears
  7. #166
    Dec 2012
    Peterborough
    176
    Quote Originally Posted by S3Alex View Post
    SQS Racing | VW 6sp DOG-KIT 02M
    Excellent Alex
    Do you know where I can source standard or non standard S2 camshafts please?
    Mark
  8. #167
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,585
    Looks great dude... however... the proximity of fuel lines to hot stuff in this pic would have me worried...
    Experience suggests that a heat shield (even though the DP is wrapped) would be of benefit as there will still be radiant heat coming off this and braided hoses are more to prevent chafing than resist heat... rubber will deteriorate fairly quickly given this is a race car and will be full on for sustained periods of time...
    Have had the odd issue with Bills race car on occasion (and a few customer BT conversions) which has made me a keen advocate of heatshielding the crap out of stuff for reliability (and in the case of flammable liquid) safety
    <tuffty/>
  9. #168
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,392
    Excellent Alex
    Mark
    Apart from EuroCarParts and similar,I'm afraid I don't,but I also don't know of anyone running non-stock cams currently.
    Sorry if that's not much help,but even at very high power,it hasn't seemed to be an issue.
  10. #169
    Dec 2012
    Peterborough
    176
    <tuffty/>
    Hi Buddy
    Yes I agree and thought of wrapping each line with heat tape (I have) and then putting sleeve over them each (need to order). I do have some heat shield material and could make and shape a shield that is held onto the downpipe with jubilee clips.
    Mark
  11. #170
    Dec 2012
    Peterborough
    176
    I think the cams are standard cast re profiled. But I don't know that for sure. What I do know is that the exhaust side lip where the small timing wheel butts up is busted and I was gonna run this as is as the car has been like that for 18 months but it worrys me. Kent have said if I send them the cam and it's standard which being cast is likley they can re profile a new one to match it.
    Mark.
  12. #171
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,585
    Hi Buddy
    Mark
    The alloy heatshield stuff (single layer should be ok but double layer is better) would work... I would be looking at fixing it to the chassis or something rather than the DP itself... whole point is to reflect the heat away from the stuff you are trying to protect, strapping it to the DP (even with an air gap) could just turn it into a radiator through radiant and conductive heat transfer...
    Slotting it in between the DP and fuel pump area would eliminate conductive heat and the air gap either side would combat radiant heat... fixing the heatshield to the bulkhead and chassis somehow is what I would be looking to do...
    Heat tape would be less effective in this case I feel and sleeving is more of an insulator but would still look to use a heat shield to reflect as much heat away first
    Had a couple of cars come in with the stuff used to go behind household radiators (the foam backed stuff used to reflect heat for energy saving purposes!!)... get a bit of heat anywhere near it and it would catch fire! lol...
    <tuffty/>
  13. #172
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,392
    Mark.
    Hi Mark,
    That may be the best option,as I'd feel very wary about racing an engine with any sort of cam problems.
    Kent are excellent,and have always had a good reputation,and the ones I had on my Cosworths were fine.
    If you aren't already using it,Zircoflex may be useful for those difficult to get at areas that need some heat shielding.....some are self adhesive,and all are very good at heat rejection around sensitive areas.
  14. #173
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,585
    ....the alloy stuff is still not the best when faced with direct heat though..
    Badgerwagen - 2012 Race Season Castle Combe - SEAT Cupra.net - SEAT Forum
    <tuffty/>
  15. #174
    Jan 2013
    48
    This sounds like its going to be an awesome car once finished!
    Try speaking to Matt Saville at Cat Cams. He should be able to help you out
  16. #175
    Dec 2012
    Peterborough
    176
    Quote Originally Posted by sje00 View Post
    Hiya
    Is that Cat Cams UK contact number or one of the dealers?
    Mark
  17. #176
    Dec 2012
    Peterborough
    176
    Just called him and all sorted, sending the cam on Saturday
    sje00 likes this.
  18. #177
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,392
    Sounds like excellent service...very quick!
  19. #178
    TDI140's Avatar
    May 2011
    1,359
    How long will it take for reveal of complete car ? I cant wait lol, looks awesome
    A3 2.0TDI FWD sportback with GT1756 250.3bhp 336ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch BBS CH
  20. #179
    Dec 2012
    Peterborough
    176
    Interior Loom
    Quote Originally Posted by TDI140 View Post
    THAT is a damned good question. Just had a call from NMS that they now can't do the wiring, so it's been sat in the workshop for 5 weeks with hardly anything done! What a joke.
    Car is coming back to me on Friday and I now need to find someone, anyone that can build me an interior loom. The exhaust cam is off to Belgium on Saturday morning and I have been told they can do a new one in 3 days. So my only issue and the only thing holding the car compeltion up is the interior loom.
    Mark.
    TDI140 likes this.
  21. #180
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,793
    Mark.
    NHN the retrofit king maybe? Seems to do all sorts of stuff!
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
  22. #181
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,392
    Mark.
    Best of luck with that,and what a disappointment to find they can't do this for you.
    I think they owe you something for that,and at least should find someone who CAN do the work for you.
    The service from your Belgian guys is typical of the "can do " attitude that signifies people who want the business and are able to supply.
  23. #182
    Dec 2012
    Peterborough
    176
    I so agree buddy. I mean why not tell me that 4 weeks ago instead of fobbing me off with it's being done each time I ring! My friends and I have found over the past few years that a lot of motorsports companys only want to deal with you if you give them carte blanche and an open invoice so they can bend you over and **** you hard style. This is why I do as much of the work I can myself by the way. It's an awfull industry from a customers viewpoint.
    Today I am ringing loom companies to see if I can get a slot anywhere.
  24. #183
    Dec 2012
    Peterborough
    176
    Quote Originally Posted by mjr901 View Post
    Who is NHN?
  25. #184
    Turbo jay's Avatar
    Leather repair specialist
    Jul 2012
    North west
    550
    Car is amazing, can't wait too see it all finished. (Nigel) username NHN, retro fits everything and a highly respected forum member.
  26. #185
    Tay
    May 2012
    Warrington
    370
    I have a friend who used to build adaptation looms for Peugeot/Citroen track cars, is this the kind of person your looking for?
    Also there's a guy called Sandy Brown on the 106 forum who makes fully custom looms for things like turbo and supercharger conversions so he may be able to do what your looking for.
  27. #186
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,392
    Good luck.
    I have no problems with someone saying they can't do something or can't supply parts etc but like yourself I really don't like bring strung along and then dumped.
    I've been very fortunate with the companies I've used for this and previously on the Cosworths but I know there are some rogues around.
  28. #187
    Dec 2012
    Peterborough
    176
    106 Forum
    Quote Originally Posted by Tay View Post
    Hiya
    Can you point me in the right direction? Which forum link please?
    mark.
  29. #188
    Dec 2012
    Peterborough
    176
    Today I have emailed 12 loom makers, let's see what they come back with. I have 4 weeks till next race!!!
    sliced likes this.
  30. #189
    wuta3's Avatar
    Jul 2012
    Manchester/Sheffield
    1,075
    There are twelve people making aftermarket/custom looms. Well i'll be.
    ​​Programmer/Web Developer, Headphone/Amp Geek
    06 SLine Special Edition Phantom Black 2.0T FSI Quattro A3
    Done: P-Flo, RevD, Sachs Organic, Milltek TBE + Res + Sports cat
    Wanted/Next:Intercooler, HPFP, Remap
  31. #190
    Dec 2012
    Peterborough
    176
    12
    Quote Originally Posted by wuta3 View Post
    There are probably a few more but it's a start
  32. #191
    Mar 2010
    154
    Hope you find a good resolution soon.
    One epic thread and build you've almost completed - you deserve the title in just the work done to date in such a short time !
    Enjoyed every line of this build thread, even if I don't understand half of it
  33. #192
    Dec 2012
    Peterborough
    176
    Quotes
    Quote Originally Posted by percymon View Post
    Ive got quotes arriving already around the 2 to 3k mark which I expected to be honest. Time is the issue because if I can get this done before June 8th I can race at BH if not it will be trac days until the big meet at BH on July 27th and 28th. Wiring loom guys always seem to be booked 2 months in advance!
    Mark
  34. #193
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,392
    Mark
    Nothing is cheap in this world,especially when it comes to racing.
    Best of luck in getting this together for June,and hope it goes well.
  35. #194
    Jan 2013
    48
    Glad to have helped you mate!
  36. #195
    Dec 2012
    Peterborough
    176
    OK Update.
    The car is down at Meridian Motorsport being wrapped (Carbon roof, Carbon roof scoop, Carbon bonnet, Carbon tailgate) In nice fabric vinyl. The cam is out and packaged up ready to go to cat cams in the morning and the car is off to TMME (Tim Mason) on Monday for a proper motorsport interior loom will I make June 8th Oerrrr.
    Lot's to do.
  37. #196
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,392
    OK Update.
    Lot's to do.
    Lots indeed,but now you have someone who knows what they're doing,and has at least a good chance of making it happen in time.
    Very best of luck,and keep the updates rolling.
  38. #197
    Dec 2012
    Peterborough
    176
    The car is coming back on Thursday
    Tim has given me an adjustable Haldex. I have a dial fom 0 to 10 with 0 being no pressure on the clutch plates and 10 being max pressure max rear wheel drive. I also have an overdide button on the steering wheel so I can turn it off and go to FWD only.
    I now need to fit the new cam and set (grind) the lash caps. I also need to give it a leakdown test as NMS said it was low on compression although I was told this is due to high valve overlap at cranking speed. I cant see how the bottom could be leaking as it's all new. The head could have a leaky valve as they were re cut. I will give it a leakdown test myself.
    Mark.
  39. #198
    JudderMan's Avatar
    Nov 2012
    Newcastle Upon Tyne
    751
    This. Is. Awesome.
    2000 Audi A3 1.8T Sport AUM K03S|Second owner|Forge 007p|CM TIP|Yellow Dogbone|Pipercross panel|Stage1Map
    WANTED: Audi A4 B7 or MK5 5Dr Golf GTi (manual)(Want to Buy December 2014 so Keep Me in Mind)
  40. #199
    Dec 2012
    Peterborough
    176
    Quote Originally Posted by JudderMan View Post
    This. Is. Awesome.
    Yeh we got the schematics for how the haldex works and stripped a busted one so we could see the pump, stepper motor for the valve and the temp sensor and went from there. In real life all the sensors are telling the haldex how much the main valve should be open or closed, the electric pump just provides the hydraulic pressure for the system.
    Of course if you try and run it with max pressure on the clutch plates you will burn them out after a few corners as its not meant to work that way it's meant to be variable based on conditions and what the sensors are telling it. I can probably get away with say 50% on them and turn it off on the straights and have say ten for starts and then dial it down to 5 or 4. I have to play with it. I think he has also mapped it to a table in the MOTEC for temp so if the oil gets too hot it will also open the valve and release pressure off the plates.
    martinivw likes this.
  41. #200
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,392
    This will in essence probably be quite similar in principle to the sort of setup that rallycrossers like Kenneth Hansen were using at one time,although he now uses a Sadev transmission as far as I can remember.
    The Haldex he used was adjustable but mapped for the conditions being raced on,so it would be somewhat ahead of a manual system,but the idea is the same.
    Great work.....this is very impressive.
  1. Backdraft Motorsport S3 Endurance Race Car build
    By Backdraft Motorsport in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th May 2014, 09:43
  2. NON VAG race car build saxo vtr stock hatch
    By monkey_lewis in forum The Project Room
    Last Post: 11th July 2012, 09:37
  3. GT2871R Turbo Kit now fitted to race car
    By Backdraft Motorsport in forum Tuning
    Last Post: 9th December 2007, 15:11
  4. RS4 race car. camber
    By heggen in forum RS4 Forum (B5 and B7 Chassis)
    Last Post: 3rd July 2007, 15:09
  5. My Race Car Wannabe
    By Justincredible in forum Photography & The Digital Darkroom
    Last Post: 31st December 2006, 19:08
