EM TuningJMB Retrofits
Results 1 to 20 of 20
    Feb 2012
    47
    replacing the casing of the left wing mirror
    Hi Guys
    My left wing mirror hits the wall in a dark evening...
    Although the mirror and its remote electronic adjustment works fine, there are cracks on the casing and looks pretty ugly. I am wondering if you could recommend any good Audi specialist in Bristol that can replace the cracked casing. Audi is trying to charge me at 200 pounds....
    BTW, do you have any idea how much it will cost at an Audi independent specialist? Labor plus the parts.
    I can find some cheaper parts on the europarts website but they do not provide any information about the color of the casing.
    A3Kent's Avatar
    Different Gear
    May 2012
    1,065
    Not sure an independent would do it? Sure it's not a coachworks job? You had a look on eBay to see if there any cases on there?
    09 Audi A3 2.0 TDI 170 S-Line SB 8P3
    - Full Leather - LED DRL's - BOSE - Cruise Control - RNS-E Mk2 - AMI - Bluetooth - Folding Mirrors -
    VCDS owner - A3 Grille Install Guide
    27,113
    Well need to know year of car & 3 or 5dr as if its a base issue they're different, I could probably get a cover, painted & fitted for less than £200
    Feb 2012
    47
    thank you for your reply. I tried ebay but can't find the identical one.
    A3Kent's Avatar
    Different Gear
    May 2012
    1,065
    Year of car and amount of doors?
    Feb 2012
    47
    My car is 58 Reg Audi A3 5 door facelift model (color black). The turning indicator is also built in within the wing mirror. Can you please pm me the possible quote?
    Feb 2012
    47
    58 Reg facelift model 5 door black A3 sportback. Cheers
    A3Kent's Avatar
    Different Gear
    May 2012
    1,065
    Is the base OK? (the part that is actually attached to your car)
    You can remove the indicator strip from your existing damaged case providing it's ok? Otherwise it's another £25/£30 for this bit alone.
    Feb 2012
    47
    Quote Originally Posted by A3Kent View Post
    Many thanks for your input. The base is ok and the indicator strip works well when I turn on the turning signal. However, when the mirror hit the wall, the mirror fell off from the casing, so I inserted it back but broke some clips. That is why there is a gap between the casing and base. I believe the clips are used to hold the casing and base together. I am not sure if those clips belongs to the casing or the base. If it is part of the casing, then the base is absolutely fine.
    I was too careless that night when I reversed my car from a small parking slot and I only focused on the car body but not the mirror
    A3Kent's Avatar
    Different Gear
    May 2012
    1,065
    You'll be able to remove the indicator strip from your broken case then.
    Not sure myself but I think you are right about the clips being part of the case, not the body.
    How about take a few photos and post them on here to show us what's broken and what's ok?
    Feb 2012
    47
    I will take some pictures tomorrow and upload them tomorrow. Cheers
    May 2012
    West Country
    172
    I bought a pair (from 2 different sellers on Ebay) for a grand total
    of 41 quid delivered. This is so I can remove the silver thief magnets.
    2009 S3 3 door. Phantom Black metallic.
    RNS-E, Tints, Piano Black inlays, Auto Lights and Wipers, Bluetooth, MFBSW,
    White Alcantara, LED numberplate lights, Black Optic Grille, Yellow Foglamps,
    K&N panelfilter, Colourmatched mirrors, S3 footplate,
    More to come....
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,407
    could always buy this and fit it yourself for free... takes 5 mins to fit!
    AUDI A5 AUDI A3 A4 A5 A6 A8 WING DOOR MIRROR CAP COVERS GENUNE AUDI PART | eBay
    gimmi a shout if you want any help on how to fit!
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Interior Lights Pack
    MODS:
    S3 facelift,
    RS3 Grill, 19" RS6, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, Auto Folding & Dimming Dumbo Mirrors, S3 brakes, US Centre Console, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    The Governor's Avatar
    Mar 2012
    Southampton
    436
    Guys, just doing a search and came across this.
    When I was cleaning my car the other week I noticed that the casing on mine is cracked, and also the indicator plastic strip is cracked too. It's fairly subtle, but if it isn't too expensive I wouldn't mind replacing the mirror cover and indicator strip.
    I didn't realise that when the knob head who clipped my mirror going the other way he'd actually caused damage, it was only when I was washing it that I got close enough to notice it.
    Ash, your link seems to be the upper part of the mirror cover... any idea where to get the lower part, and is it easy to fit?
    Cheers in advance
    27,113
    Little confusing as you say about changing the cover, then you mention lower part which isn't part of the cover, can you be more specific, also 2009 or 2011 onwards?
    They're expensive from audi, led strip about £30 or so, the cover is about £90 or more
    Mar 2012
    Southampton
    436
    Sorry Nige, what I mean is, the out part of the mirror casing that faces the front of the car. In the link Ash posted to the Ebay auctions, they're selling that part, but it doesn't have the lower LED part...
    If that doesn't make sense I'll take a photo lol
    27,113
    Yeah led part is about £30, but probably find cheaper on ebay, but make sure its the correct one.
    Phil-1's Avatar
    Sep 2013
    Harrogate
    1,110
    Just found this. I want to paint just the cover. It has a scratch about 4cm long on it
    Do I remove the cover ( don't know how easy this is) run the car with the cover off or should I buy another cover and get it painted and fitted?
    Phil
    Audi A3 8P Sport Back 170BHP (And I Love it)
    web page: philseagust.co.uk
    E-Mail:info@philseagust.co.uk
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    could always look at something like this... Not sure these are the exact model.
    Audi A3 A4 A6 S3 S4 S6 Chrome mirror covers housings caps wing mirror casing | eBay
    Phil-1's Avatar
    Sep 2013
    Harrogate
    1,110
    Not sure I link them :-)
    Anyone know if you can buy them already painted from Audi?
  1. a3 wing mirror where is the part number
    By Syvo in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th April 2011, 23:23
  2. a3 wing mirror where is the part number
    By Syvo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th April 2011, 15:35
  3. A3/S3 wing mirror casing removal/replace
    By RicoS3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th May 2010, 20:23
  4. The little c***s stole my chrome wing mirrors!
    By Haglos in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th October 2009, 20:37
  5. Can you fit the new audi a3 wing mirror with indicators onto a 53 plate?
    By Digzz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th January 2009, 18:42
