EM TuningChris Nott
    Apr 2010
    Nottingham
    230
    Question Changing low pressure fuel pressure sensor G410
    Car started misbehaving the other day. I had started the car and was sat in it on the phone. The car was idling fine and then it would just cut-out. It did this about 3 times during the 10 mins I was on the phone. Then when I drove off it seemed to really struggle at low revs (around 1500rpm) in 2nd gear and above. Occasionally I would suddenly lose power and then get it back again. It has also cut out a few times when the revs have dropped to idle.
    So............VCDS:
    Address 01: Engine Labels: 06F-907-115-AXX.lbl
    Control Module Part Number: 8P0 907 115 H HW: 8P0 907 115 B
    Component and/or Version: 2.0l R4/4V TFSI 0040
    Software Coding: 01030003180F0160
    Work Shop Code: WSC 66565 257 00032
    VCID: 37769FC446690AA0D0F
    3 Faults Found:
    012555 - Low Pressure Fuel regulation
    P310B - 008 - Fuel Pressure Outside Specification - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 0
    Fault Frequency: 9
    Mileage: 49630 km
    Time Indication: 0
    Date: 2013.01.17
    Time: 07:31:57
    Freeze Frame:
    RPM: 2092 /min
    Load: 14.1 %
    Speed: 53.0 km/h
    Temperature: 72.0°C
    Temperature: 2.0°C
    Absolute Pres.: 1000.0 mbar
    Voltage: 14.605 V
    004767 - Low-Pressure Fuel Pressure Regulation
    P129F - 001 - Pressure too High - Intermittent - MIL ON
    Freeze Frame:
    Fault Status: 10100001
    Fault Priority: 0
    Fault Frequency: 5
    Mileage: 49630 km
    Time Indication: 0
    Date: 2013.01.17
    Time: 07:33:20
    Freeze Frame:
    RPM: 2301 /min
    Load: 28.6 %
    Speed: 43.0 km/h
    Temperature: 41.0°C
    Temperature: -4.0°C
    Voltage: 14.605 V
    000135 - Fuel Rail/System Pressure
    P0087 - 002 - Too Low - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 49634 km
    Time Indication: 0
    Date: 2013.01.17
    Time: 07:37:34
    Freeze Frame:
    RPM: 1964 /min
    Load: 50.6 %
    Speed: 48.0 km/h
    Temperature: 75.0°C
    Temperature: -3.0°C
    Voltage: 14.732 V
    Readiness: 0000 0000
    I've read a few posts and it sounds like changing the G410 sensor might be a good place to start. Should have one tomorrow. Is there anything I need to do prior to removing the sensor? As it's on the low-pressure side of the fuel pump i'm hoping not. Just don't want fuel peeing out all over the engine and myself. Is it just a case of undo bolts, remove old sensor, fit new one?
    Cheers,
    Adi
    '07 Phantom Black S3
    Superchips Bluefin Stage 1
    TTRS FBMFSW
    MY11 Rear Lights
    Auto-lights/Auto-Wipers/Auto-dimming rear view mirror/CHLH retrofit
    bmh.01's Avatar
    Apr 2012
    Nuneaton
    279
    Quote Originally Posted by ADi Nuff Valves View Post
    Pretty much, yes.
    Acheron's Avatar
    Jan 2012
    South Africa
    263
    Quote Originally Posted by bmh.01 View Post
    Pretty much, yes.
    +1.
    Just clear the code afterwards as well.
    Current: 2010 Audi S3 Sportback S-tronic
    Ex: 2007 Audi A3 Sportback - 2.0T DSG
    Ex: 2008 Opel Corsa OPC
    Ex: 2004 Opel Corsa Lite
    Ex: 1978 VW Beetle
    Apr 2010
    Nottingham
    230
    Awesome thanks.
    Just hope I can make it from work to the stealer to pick up the sensor and then back to mine (because of a) the car not running well, and b) the snow)!
    TTRS FBMFSW
    MY11 Rear Lights
    bmh.01's Avatar
    Apr 2012
    Nuneaton
    279
    Have you been through the fault finding procedure for the low pressure sensor?
    Only when it happened to mine I never got the low rail pressure fault (until i'd been through the procedure that is) and it ran perfectly other than the EML. Mine was stuck at 11 bar permanently.
    Apr 2010
    Nottingham
    230
    Swapped the sensor this morning in the snow. Have been out for a short drive and seems to be ok. Will see how it is over the week.
    TTRS FBMFSW
    MY11 Rear Lights
  1. 16575 - Fuel Pressure Sensor (G247) Implausible Signal
    By jb0o in forum VCDS (formerly VAG-COM) forum
    Last Post: 31st March 2014, 01:42
  2. Golf ED30 Low Pressure Fuel regulation
    By Eric Ng in forum Volkswagen and other VAG
    Last Post: 26th February 2012, 19:09
  3. A4 (B7) 3.0 TDI Fuel Pressure Sensor
    By sc00byd00byd00 in forum VCDS (formerly VAG-COM) forum
    Last Post: 13th April 2011, 15:00
  4. G410 low fuel pressure sensor issue on S3
    By DemianM in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th November 2009, 00:16
  5. Fuel Pressure Regulator
    By imported_SYNAPS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th January 2005, 16:06
Tags for this Thread
