Sky InsuranceAH Fabrications
    tdi-man's Avatar
    Jul 2009
    1,612
    EGR COOLER DELETE
    had my EGR cooler deleted today as means as the egr is switched of in my map. Question is is there any improvement in removing the egr valve itself and replaceing with a allard kit or is it a waste of money ?
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm (NEEDS A NEW MAP)
    TDI140's Avatar
    May 2011
    1,350
    i think its just adding a little weight whilst its there other than that its not worth removing wont improve any more than an egr delete does, im not 100% sure though maybe someone else can help ...
    A3 2.0TDI FWD sportback with GT1756 250.3bhp 336ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch BBS CH
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    748
    They can leak, so it's just a reliability thing by removing.
    Unicorn Motor Developments. Bespoke Calibration and Remapping Services
    www.unicornmotordevelopments.com
  1. audi a3 egr valve and egr cooler delete
    By zaidar61s in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th July 2012, 11:50
  2. EGR cooler torque
    By prs999 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 18th November 2011, 10:04
  3. 1.8T EGR Valve Delete Help
    By dany2k in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th December 2010, 12:51
  4. 2005 tdi EGR Cooler click
    By P Crr in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 11th September 2010, 10:05
  5. Do 2.0TDI BKD EGR Coolers Really Leak???
    By Tonyc in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st August 2010, 13:03
