Badger5JMB Retrofits
Results 1 to 7 of 7
    Mar 2012
    45
    Coolant Warning Light
    Completely drained and changed my coolant at the weekend. Running fine, no overheating and bottle full...however the coolant warning light keeps coming on when i first start up.
    Any suggestions???
    Would an air lock cause this without it overheating???
    Fossie
    Rhubarb Triangle
    3,969
    Scrape prongs in coolant bottle with a screwdriver and see if it sorts it. Very common problem evidently !
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,525
    as above very common
    Mar 2012
    45
    Brillant. Will give it a go.
    Odd that it didnt do it before though
    Mar 2012
    45
    Seems to have done the trick!
    Cheers guys!!
    Dec 2011
    MIDLANDS
    253
    Does anyone have a picture of where the rads usually fail on A3s?? is it usually at the bottom cormers?
    A3 2.0TDI S LINE, Awesome remapped, ITG, Milltek, S3 Front + Rear bumpers + Sideskirts, Cruise and slammed on coilovers. NO SMOKE - NO POKE!!!!!
    Fossie
    Rhubarb Triangle
    3,969
    Mine failed bottom passenger side.
  1. Coolant warning light in A4
    By steviet666 in forum General Technical / How To
    Last Post: 10th January 2008, 16:41
  2. coolant warning light DIS 2.0 TDI (2005)
    By john_cook in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th December 2007, 17:10
  3. Help - coolant warning light on S3
    By bantam1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th January 2007, 16:17
  4. coolant warning light
    By milie in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th September 2005, 14:48
  5. coolant warning light and buzzer.
    By imported_55spike55 in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th September 2004, 19:38
