EM TuningSky Insurance
Results 1 to 9 of 9
    Nov 2012
    9
    Buzzing noise coming from engine bay 2.0 TDI
    Right first post and not a good one!
    I was changing my headlight bulbs earlier and when I fit them I turned the key in the ignition(not starting engine) to get my lights on and heard a funny buzzing electrical sounding noise coming from the engine? When removing the key from the ignition and turning the lights off the noise carried on for around a minute.
    In a panic I put my old bulbs back in but the noise was still there!
    Anybody able to put my mind at rest here? Or is something wrong?
    My car is a 57 plate 2.0 TDI 170
    Jun 2011
    Great Melton Norfolk
    1,349
    I have a T5 van that does the same , been doing it for 3 years now. Never have figured it out,scanned it several times and no codes .
    Nov 2012
    9
    Glad it's not just me then. The best I can explain the noise is a high pitched electrical sound?
    When I'm booked in for a service at Midland VW ill be asking their opinion.
    27,097
    Yeah they make several noises on ignition turn, dont worry yet lol.
    chris.vincent3's Avatar
    Apr 2012
    UK, Portsmouth
    601
    Have you guys fitted aftermarket headlights by any chance? Had this problem on my MG ZR with aftermarket headlights, turned out to be the motor in the passenger side headlight so i just unplugged it and the buzzing stopped.
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    Check the headlight leveller hasn't moved out of place (for the buzzing noise), the high pitch noise is probably just the EGR motor on the intake, amazing what's sounds you start to notice when you're looking for them.
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    Nov 2012
    9
    They aren't aftermarket headlights just brighter bulbs. I thought it may have been the headlight leveller but when using the manual adjuster it still works fine, if the leveller was at fault would I still be able to adjust?
    Jord's Avatar
    Dec 2010
    Ellesmere port
    273
    Sounds like the egr intake manifold flap buzzing, I noticed mine before changing my bulbs
    Jun 2011
    1,349
    Mine generally makes a groaning /buzzing noise after the engine is turned off. It can last for up to 3 minutes gradually getting quieter.
  1. Help weird noise coming from engine.
    By bad-vw-boy in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th March 2010, 22:02
  2. Vibrating noise coming from engine
    By paulious in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th January 2009, 12:39
  3. Zipping noise coming from Engine compartment below 2000 rmp
    By randle in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th March 2008, 13:29
  4. loud blowing noise coming from engine when started up......?
    By rockstar in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th October 2007, 17:55
  5. squealing noise coming from engine
    By lowrider786 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th April 2005, 09:35
