AH FabricationsJMB Retrofits
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,973
    does the cambelt vibration damper need changing on bkd?
    Im on about the shocker absorber/damper where the cambelt is fitted (if bkd engine has this) is it better buy genuine parts/waterpump from audi ? im getting em done by local mechanic. Its been exactly 5 years and 42k later im sure it needs doing now as its been 5 years,even though it aint done the miles,genuine or non genuine?
    Full leather/19"wheels/cruise/
    IceHanger's Avatar
    Dec 2011
    West Mids/North Worcs
    291
    you can buy a complete kit now that has of these parts in, Personally I change everything in teh timing belt loop, always buy Genuine timing belts/kits, cheap rubbish are not worth it.
    I've Always used Gates products over the years, if you need help getting part numbers give Gary a call on there technical line 0844 980 0062, he knows his stuff.
    IceHanger
    2011 S3 8P 5DR Black edition,
    2013 TT TDi BE with lots of toys
    Previous Vehicles:
    Audi S4 B6 4DR Big fuel bill edition
    Audi TT TDi S-line Quattro
    Skoda Octavia 4x4 Turbo,
    Skoda Octavia VRS Estate,
    Vauxhall VX220 Turbo,
    MGF VVC,
    Vauxhall Astra GSi,
    Alfa 33 Cloverleaf,
    Tons of Minis
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    thanks,il buy from audi i think,like you say not worth it over a few quid,Hopefully mechanic will not loosen the 3 top pulley(torsion value bolts) But as the belts coming off its wise to check the torsion value via vcds or do the bolts just have to be in the center? or before taking the belt off,is it easier to find out when the locking pins are fitted?
    Quote Originally Posted by IceHanger View Post
    IceHanger's Avatar
    Dec 2011
    291
    sorry are you saying VCDS tells you the torsional value of your belt?
    Info about the TVD & OAP here
    https://www.gates-online.com/GatesEU...031_T38306.pdf
    Axillary belts should be changed as well as your timing belt, no body tends to but it's likely to cause more problems if you dont.
    IceHanger
    Previous Vehicles:
    MGF VVC,
    Vauxhall Astra GSi,
    Alfa 33 Cloverleaf,
    Tons of Minis
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    im not on about alternator damper.
  1. A4 cab 3.0 petrol-when does the cambelt need doing?
    By reggieroo in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th July 2011, 03:17
  2. gear box oil - does it need changing?
    By barters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th April 2010, 13:02
  3. When does the cambelt need changing on a s3?
    By Tekin in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd April 2008, 10:26
  4. Does the concert 2 need coding for ipod interface?
    By Garth_S3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th March 2008, 15:25
  5. Does the 2.5 TDi have a cambelt or Chain?
    By G4JSG in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th September 2006, 12:26
